Even if you don't get jolts/vibrations it's worth upgrading your engine - you may even get better MPG out of it. I'm planning to ring my dealer up soon about this.
Interesting analysis as well - I think you meant turbocharger rather than supercharger? Though they are the pretty much the same thing except turbo's rely on exhaust gas to generate power.
I notice when 2cyl mode is in effect based on the sound - a bit like a washing machine when it's spinning. But it never kicks in when the engine is cold, or in 1st or 2nd gear.
It also always switches off when the speed drops below 20mph or if I force S-Tronic to downshift. If I'm cruising at 30mph it'll kick in - and I can hear it very clearly. When I accelerate from 30mph to 40mph there definitely is a slight lag in power initially but generally it seems normal.
COD on my car seems very picky. It has to be at least 3rd gear, at least 20mph, very light load, flat or downhill roads only, engine fully warmed up etc. Perhaps a COD engine behaves differently depending if it's connected to a DSG box or not.
I received my car towards the end of April 2015 so I'm assuming it has the 2nd from latest update - TPI 2037323/3 ?
I went to the garage there two weeks ago, and there were no updates since the last time (October). I'm pretty sure I have the TPI 2037323/3 (seen on paper).
J4MMYz: what is the brand of your fuel? And do you use SP95, 98, E10?
Yeah, I meant the Supercharger because the supercharger works first then hands over to the turbo. The handoff is never noticeable though - and you won't notice the supercharger delay since yours is the DSG, they drive very different - which is why you never have 2 cyl in 1st or 2nd gear as DSG will never let you rev it (unless you are in manual shift mode) - if you let it rev you'll notice here and there the rumble/vibrations - it won't always do it though. Thats why I agree with it shouldn't be coming in on 1st or 2nd gear at all. Thats when it's most noticeable now (manuals)
I think your software would be the /2? This update came in May 2015. I collected my car on Dec 2014 - one day before 2015 (believe me I was cross they registered it and didn't wait a day) so we was on the same software I guess. The May 2015 one gave some improvement and upped the revs for it to kick in to 2 cyl - but this latest update (no idea when it was released though, probably a few months ago) is a massive improvement.
I agree, update your car even if you don't notice 2 cyl. I'm absolutely certain this is an update for the engine either way, so if your car went in for a service that should be something they install also. Should be anyway!
Also reading on, the engine did jerk/jolt yet. It's not any other fault since these updates have in the description 'to diminish 2 cyl jolts/vibrations' - which since this latest update, my car hasn't jerked/jolted once.
I totally agree that 2 cyl shouldn't engage in 1st or 2nd gear. When it does engage in 3rd it's not noticeable most of the time + i'm always revving low in 3rd when I stay in that gear, normally when I drop to 2nd (in traffic situations) and just let it sit around 2.5k revs thats when it rumbles (sometime) mainly when I'm SLIGHTLY accelerating, if you let off you won't notice it as much (might do it might not)
If you was revving 6k/5k then it won't engage, I think 2 cyl mode won't engage over 3.somethingk revs.
Try this: 2nd gear along a quiet road, rev about 2.5k. Keep doing it - don't do it once, not experience it and give up keep trying - I remember someone with an s-tronic did try this and noticed it slightly - as I say, it's not like it's shaking the car to hell, you just notice a slight rumble which sometimes is worse than others depending I guess on how much load there is - which Audi still need to tweak down a little, done a good job so far though. As I say, most of the time when 2 cyl rumbles is probably due to either timing or too much load.. but yeah, I agree 2 cyl should not come in 1st or 2nd gear at all... thats when it's most iffy, as you say it's an accelerating gear + if you are in traffic and it does come in to 2 cyl whats the point when a moment later it's back out again? All it does is mess around in those situations and won't save any fuel.
Totally agree - worth getting upgraded anyway. You might get better performance...and if it makes it worse, take it back to Audi and reverse the update. Low risk.
I'll give that a try tonight. So 2nd gear S-Tronic? 2.5k revs would be a low speed in 2nd gear...20mph??
So should I expect it to jerk like it's losing then gaining power? Or the whole car should shake/rumble?
