Mine is the 140 with a manual gearbox...Thx. for the replies.
I forgot to say that the vibrations was in Audi A3 1.4 TFSI COD 150 HK cars with manual gear boxes.
No, it's the COD alright. I've had an Audi Technician driving the car. He has confirmed the vibrations comes from the COD.No the COD cannot be deactivated, I would suggest if your car is vibrating that badly it isn't anything to do with the COD.
I drive a mix of high and low RPMs, usually accelerate quickly but then cruising at a low RPM and constant speed with light throttle and 2-cyl mode activated. How can I try to replicate the issue? Is it at a particular speed or gear?
I can induce a slight vibration in 4th at below 1200rpm on a light pedal, but I think that is due to asking too much as above 1200rpm it disappears.
Well I can only speak as I find and my 1.4 COD car does not have these vibrations - it is the smoothest engine and gearbox that I've ever had.
No offence to the technician but how would he know? He may know that only COD-equipped engines produce the vibration but that's not the same as claiming it's the COD system which causes them. He's a technician at the end of the day, not an engine designer. Whilst no doubt possessing a great deal of knowledge, I very much doubt he has enough of a detailed knowledge of the engine design to be able to say for certain that the COD system is what's causing the issue.
came from a diesel so even a slightly vibrating petrol is way smoother!![]()
To (try to) reproduce it:
1. Set the 2-cyl indicator on the screen. Not necessary but it helps.
2. Drive in any gear between 1500 and 2000 rpm.
3. Step moderately on the throttle. You should press the pedal as much as you can without entering 4-cyl mode (vibrations happen only in 2-cyl mode).
It's very easy to determine whether it's the COD that is causing the vibrations. The COD is only active when the engine is warm. When the outside temperature is minus 4 degrees (Celsius) it takes app. 10+ min. before the COD sets in. When plus 4 degrees its takes app. 5+ min.No offence to the technician but how would he know? He may know that only COD-equipped engines produce the vibration but that's not the same as claiming it's the COD system which causes them. He's a technician at the end of the day, not an engine designer. Whilst no doubt possessing a great deal of knowledge, I very much doubt he has enough of a detailed knowledge of the engine design to be able to say for certain that the COD system is what's causing the issue.
if these 'vibrations' are less than can be felt as normal from a diesel engine then where is the problem.
Yes but it is a petrol engine different from other petrol engines that are commonly used. I wasn't actually comparing it with a diesel engine per say, but suggesting that if the vibrations are much less than a diesel, and much smoother, then what is the problem if the techies are now saying it is normal. If it isn't and something goes wrong you can come back to them and prove they were incorrect.It's true that the CoD vibrations are considered normal by Audi. But I don't agree with
The problem is that this is not a a diesel engine. You don't expect those vibrations from a petrol engine. Comparing it with a TDI engine is fallacious.
Imagine you had a TDI with unusually large consumption and someone said "Don't worry about that, my petrol engine has even greater consumption!". Would you be satisfied with that argument?
So is this still an issue on Audi's bought today? I'm getting an A3 1.4 TFSI COD 150 S-Tronic on April 20th (wish I was saying February 20th...) so I'll be sure to try this out.
To be honest I'm fairly tolerant to vibrations like that so I may not notice but I'll post again if I do find it. I'm also a little spoilt by my Dad's 2006 A6 2.7 TDI Multitronic, which is ridiculously smooth. Don't think I've ever felt a gear change in the 8 years he's owned it (and I've driven a good 5000 miles in it). Feels like it has only one, very long, gear.
Separate but sort of related question - if you put it in "sport" mode, does that disable COD so it always remains on 4 cylinders?
Here's my view. The vibrations are there. Some people notice them, others don't.
There are engine software updates that seem to reduce those vibrations (see earlier on this thread). Your new car will surely have those updates included. My advice: try not to focus on those vibrations. If you don't notice them, lucky you. If you do, think they are normal and try not to pay attention to them.
Apart from those vibrations, it's a great engine. Large power, large torque, proggressive. Low noise and consumption.
leosayer1: Have you read this thread? There are many of us who notice. You don't notice? Fine. Maybe your engine doesn't vibrate so much. Or not at all. Or you are lucky enough to be less sensitive to vibrations. But Lars is not the only person who notices the vibrations. Again, read this thread.
I notice the vibrations as well. They don't annoy me in the slightest in fact I find it gives the car some much needed character, along with rattle noises that come from S-tronic gearbox.
I like the fact that the engineering which has gone into making this car fuel efficient and lightweight occasionally makes it presence felt in the background, but it doesn't prevent half decent performance being a toe-flex away when the mood takes you.
I guess some, not you, feel the need to drive their cars so as too deliberately create a perceived issue.
