VCDS Help - Hard Start
lgooch
Well-Known Member
East Manchester In the Hills !
Got a 2010 VW GOLF GT TDI which has thrown a few codes up. All come back when cleared.
I have fitted a skoda B tooth module so I think I know why the codes are coming up for the phone, however the horn, battery and heated seat all stump me as they all work.
the car when left for a few days is a bit intermittent to start (it takes 1-2 secs to crank and fire) but other than this is fine.
Any help and advice appreciated.
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Tuesday,29,April,2014,19:54:07:34095
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
VIN: WVWZZZ1KZAP139825
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB) Labels: 03L-906-018-CFF.clb
Part No SW: 03L 906 018 HW: 03L 907 309 R
Component: R4 2,0L EDC H20 9818
Revision: 42H20--- Serial number: 00000000000000
Coding: 00190012042500080000
Shop #: WSC 00600 210 88537
ASAM Dataset: EV_ECM20TDI01103L906018 003011
ROD: EV_ECM20TDI01103L906018_VW36.rod
VCID: E7DB57101EE87B26BAD-80B2
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 163B400D09250003681302E6901E0082340000
Shop #: WSC 00028 028 00001
VCID: 78F9846CCB5664DEA37-802D
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 00028 028 00023
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_SE36.rod
VCID: 6ED5A234B1122A6E79B-803B
1 Fault Found:
9479441 - Control Circuit for Front Right Seat Heater
B10A5 11 [008] - Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 43
Mileage: 98258 km
Date: 2047.14.03
Time: 10:11:50
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0575
Revision: 00103 AG
Coding: 4E180A3A9837F1C044080080400081E447090088725D8560648000200000
Shop #: WSC 00028 790 00206
VCID: 30697C4C63A67C9E2B7-8065
Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer 19021 21 0512
Coding: 009795
Subsystem 2 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 3 - Part No: 1K8 951 605
Component: LIN BACKUP HO H09 9002
2 Faults Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 98257 km
Time Indication: 0
Date: 2047.14.03
Time: 10:07:12
Freeze Frame:
Term 15 Off
Voltage: 14.25 V
OFF
ON
Term 50 Off
OFF
OFF
01598 - Drive Battery Voltage
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 6
Fault Frequency: 1
Reset counter: 51
Mileage: 98431 km
Time Indication: 0
Date: 2047.14.07
Time: 19:30:22
Freeze Frame:
Term 15 On
Voltage: 14.00 V
ON
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 D HW: 5K0 959 655 D
Component: AirbagVW10 037 0606
Serial number: 003FKD04EYGX
Coding: 00003133
Shop #: WSC 01383 790 00059
ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3B735B60B2E08FC68E5-806E
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1F53624FZZZ1
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME2B272350ZZZQ
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME36575118ZZZR
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME082C517DZZZ/
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000732
VCID: 78F9846C0B5664DEA37-802D
Subsystem 1 - Part No: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: 00000226
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 970 N HW: 5K0 920 970 N
Component: KOMBI H03 0305
Coding: 470F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod
VCID: 397F4168B8DCBDD69C9-806C
Address 19: CAN Gateway Labels: 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0112
Revision: H07 01 Serial number: 010310F1000664
Coding: E9807F06000612000003
VCID: 69DFD12840FCCD562C9-803C
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
VCID: EADD2E240DFA464EA53-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667832505
Coding: 010000
VCID: 26459A145162222EC1B-8073
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2140
Coding: 0000692
VCID: 3363734052B04786565-8066
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 70 3001
Revision: 00H17000
VCID: 316F7948A8AC7596249-8064
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Coding: 0000692
VCID: 3461705C57BE40BE4FF-8061
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8067099
Coding: 0100040004
VCID: 65C7DD186CE4E936081-8030
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 00028 028 1012545
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 35674D585CC459B6781-8060
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 D HW: 3C8 035 730 D
Component: Telefon 022 0982
Revision: -------- Serial number: 35502105101696
Coding: 020000000100000000000101
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi_SE36.rod
VCID: 2441801C2F5ED03EDFF-8071
2 Faults Found:
9457427 - Left audio channel for speech/telephone
B104F 13 [009] - Short to GND
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 98257 km
Date: 2047.14.03
Time: 10:06:56
13636352 - Control module not coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 2
Mileage: 98257 km
Date: 2047.14.03
Time: 10:06:56
End ---------------------------------------------------------------------
