Drivers door handle
ian.stewart
A silly little thing, The outer cover on the outer door handle is loose and rattles, any way of tightening it up??
I have done this if you get on your knees and lift the handle there is a tab you can slide accross and the handle comes off use some sticky foam.tape and reattach....... Job done!
Yeah its really annoying basically if you lift the handle you slide a pin out. I used a pick put some wd40 on and mask the surrounding.area just to protect the paint a little incase of slips.
Reactions: barkclark
