- Joined
- Jun 20, 2015
- Messages
- 555
- Reaction score
- 297
- Points
- 63
Hi have to agree Rod the RS4 Avant would look so good, here's another for good measure
More picsHi have to agree Rod the RS4 Avant would look so good, here's another for good measureView attachment 132112
Yes been thinking about it only not sure which springs are needed for the already lower s line springs to get right drop unless you can help cheapest method preferrednow if you were to drop the ride height another 25mm allround it would be spot on......nice.
Any special products your using ?Didnt come up to bad still need more doing when i get time![]()
Sent from my SM-G920F using Tapatalk
well you know the old saying martin, "if you've got it , flaunt it" very nice chap, don't forget the centre caps , I can only award you 8 out 10 so far with out them.Used chemical guys butter wet wax![]()
Sent from my SM-A300FU using Tapatalk
cheers Rob still wish i had a black car tho like yours ceentre caps im workin on as wanted to split and paint also need to get rid of the amber lense in headlight as have clear lense to go in.well you know the old saying martin, "if you've got it , flaunt it" very nice chap, don't forget the centre caps , I can only award you 8 out 10 so far with out them.
What does this clay do and how do you use it ? ThanksJust clayed it then used jays ceramic wax i still need to machine it as it has light swirls
I'll have a look out for this thanksI used dodo juice clay bar and it smooths the paint so you get a better finish on products that you apply after
What is qd ? Thank youThen if you run back of you finger over paint work it really smooth like glass
You can use qd to keep the panel very wet and slide claybar across and you will feel the panel get smoother then move onto next panel till whole cars done and then when you apply a wax over the top it will give it a better finish
Quick detailer or you can buy a clay bar kit which will come with all you needWhat is qd ? Thank you
Sent from my SM-G925F using Tapatalk
Ok will do thanksWhere are you from??
and manchester
Im from nuneaton near coventry im not to sure what shops are near you sorry i couldnt help further
its ok thanks for info, ebay has dodo juice kit
Lowered finally and new Rotiform rse in matt anthracite. Will get better pics![]()
Looking very nice. What size did you go for 18 or 19 as I'm going from 19 to 18 when I've finally finished my car so just getting some ideas of how it will sit
Cheers. There 8.5x19 et45. Lowered on Ap 40/30 springs. Old wheels where in the car when that pic was taking, So rear is slightly higher now.
Sory ye there et 35. 235/35/19 Gona play with some spacers to get it sitting betterLooks spot on
Suprised they're only et45 as they seem to sit quite nicely flush with the arch unless they're fairly wide tyres or your running spacers (or maybe I'm just overthinking it haha my et45's seem to be in a bit more so I used spacers to bring it to around et35).
Nice! Ye 18s and air you'll be sweetI think I should be able to pull off 18's as I've just installed air ride I'll just have a bit more profile little more stretch as I'm going 9.5j rear with et20
I might be biased ha But i think red is the nicest colour in them. Mine gets deeper with every waxdare I say it, very, very tasty.....I like it a lot.....makes me want to go out and buy a red avant now with new alloys....or worse case just new alloys....
Is that shocks and spring set or coilovers ?Some better pics![]()
Cheers mate..its still winter here. It was 23 degrees todaygreat pics, great car......and great location, I would have your car and i'd swap wet old blighty for your location right now, well to be honest I'd swap anytime....
nice one chap.
