I am not the expert and was just throwing the idea out there but *if* this is a cause then wonder if it would be more likely to be the transition between WOT & then slowing down (& hence localised boiling as water flow reduced before heat dissipated) than a normal engine warm up or switch off cycle; the latter being covered by the over-run water pump and a slower end of journey (unless it's a rapid stop and start-stop kicks in)
Those engines are designed to run pretty hot so less headroom to absorb heat soak when coolant flow reduced.
