Essexman's A3 1.8t Sport project thread
My friend tried to do a generic remap with his regal/ kess hardware/ software- it stated on his system '1996 onwards AGU' can be done through the obd port, but it kept saying basicly 'computer says no'
I told him cheers for trying but i dont mind going to specialist place for a custom stage 1 map,
He was then saying his system software is saying ''for the 1998 8l agu'' it needs to be a ecu out/ chip out job!
Im sure ive heard/ seen on here others with same car as mine having a stage 1 through the obd port! ? weather it be mobile call out or at a dyno centre etc
Maybe is it just the software he is using that needs to be updated or changed to remap my car ? or is it literaly all our 8l mk1 1998 1.8t' agu's have to have the chip in ecu pulled out ?
20141129 203058
20141201 214410
One of the fairly recently purchased uprated upgraded l.e.d sidelight bulbs, decided to flash all crazy, (maybe it knows its nearly xmas) So tried to look at it, make sure its connections are ok etc, but it kept doing it, flashing away whilst driving, just when i was thinking 'well they are the best white clear bulbs i can get (short of hid kit)'
I thought well if theres a chance they are going to keep doing that (even though they say last a lifetime etc) i might aswell do the old man style thing and put the originals back in, hate the fact they are dark and yellow'y, :-( but love the fact they just work with no probs :)
A pic of horrible old sidelights (that work unlike my experience with l.e.d's)
Just picked these rear facelift lights up from the yard next door to my mates :)
10624894 1501473840119073 985850200800261874 n
10154371 1501473800119077 7618218784948776056 n
Reactions: mikey83
Earlier on in the thread i mentioned the 'Brake light switch' near the brake pedal failed, so i got a new one from Euro's, they said this is the only one on our system that will fit your car when we put your reg into our system, 2pin or 4pin & yours is a 2pin- so there you go, This was slightly the wrong fit/ shape and size, I orderd one from Ebay for £2 that matched the oem/ original perfectly & worked perfectly too - -
- Untill now, as i noticed No brake lights :-/ hopefully not been like that for too long on the roads
Fiddled with the switch & the lights did come on but was tempremental, ''on closer inspection it had even grown a boob'' ! ? (I dont know either), ill post a pic when i can
So i walked into a GSF today And the manager assured me his one is the right one for the car (looks 'slightly' different to the other two again) So hopefully 3rd time lucky with this one, ****** things
Good thread so far but just incase you didn't know that flutter sound your getting is not good as it's a broken diverter valve so you need a new one anything other than a crisp kachoo is broken or sticking and surging the turbo to spin the wrong way not good dude
They are cheap enough, and my friend needs one for his golf anyway so ill buy an oem aswell
Reactions: Mrharris2
No it's a sin of a faulty dv lol it sounds good but no good for the car I bought a recirc valve of ebay 26 pound metal the same as a forge one but no brand
Reactions: Essexman
Been a bit stalled what with Xmas, & some bad weather, but things will pick up in 2015 - and this is good inspiration to start :) - The 1st Audi Tuner Mag, (with essential reading food)
20150109 155927
And a mention of the Forum -
20150109 155849
For sale! Audi a3 1.8t sport ''with another faulty brake light switch'' Agghhh!, wish i could get to the bottom of the prob, if i touch the switch with my hand whilst pushing the pedal sometimes the brake lights come on, i thought maybe im kicking it with my brake foot but it cant be, its a bit like the reverse style switch bit of plastic was 'slightly' off the pedal nub to the side, now it seems more where it should be but still no brake lights
Get a genuine brake light switch mate .... Are you fitting it correctly? Don't touch the pedal put switch in and twist till you hear a positive click
Yeah I'll have to buy a new one from audi if I'm stuck I'll call you lol
No worries you attending Stafford audi meet?
Well that was weird, cheers for answering a3 lee for me mrharris2 lol, done all you said Lee but still intermitant, as not to be defeated- took it out and took it apart at a friend's with a multi-meter, couple contacts loose, so made sure they wont be loose anymore, extended ratchet, put it back together & in the car, now works fine, yet time will tell, went to audi anyway- they only had 2004 onward in different shape, might try vw (just to have incase current one goes again
Brake light switch still currently working which i hope stays that way lol, Also car has been well serviced so used mates equipment to remove service light on dash, his equipment also threw up a temp sensor fault, will buy a new one and change the water/ anti.freze while im at it
After seing the ''pul'' (partsulike) advert in the back of the new Audi Tuner magazine, I purchased a set of L.E.D bulbs for the Audi A3 1.8t sport 1998, There was a teething issue with stock, but after a few nice Emails they sorted me out with a set, I would recommend them,
They were –
front sidelights - 2x 9 smd led t10 w5w 501 194 xenon white capless
interior front left & right - 2x 5 SMD LED XENON WHITE 233 T4W BA9S BAYONET
interior front middle - 1x festoon 31mm / 32mm XENON WHITE 4 SMD LED
interior rear - 1x festoon 6 smd 39
numberplate - 2x Festoon 6 smd 39
Note that other models/ years may have slightly different bulbs or need canbus error free, best to check
Before and after from standard halogen sidelight bulb to smd led bulb, shows a bit 'bluey' on camera but is white to the eye
20150201 005134
Fitted the new Diverter/ recirc Valve, same as Mrharris, no leaks, quieter !, but its a bit of a boy racer pshhhh now, kind of preferd the 'flutter' lol, but if this is how its supposed to be :)
Also fitted a new silicone throttle body/ intercooler hose
20150206 234856
20150205 190605
20150203 134305
What a coincidence I fitted my fmic yesterday and after a few pulls my diverter valve broke and now flutters really loud lol does sound awesom but gotta purchase another that's lasted me 2 and a half years, I also prefer the flutter lol but no good turbo surge
Nice one, just a thought but has your recirc tube just came unscrewed ? i notice its a screw thread, i just done mine up tight, & was carefull when wiggling hose on/ off
Had to cut a good 3inch off the TB - I hose to get it to fit, was not a straight fit strangely, still recommend creation motorsport though, the new valve is on the scuttle pannel in the pic, if the pic looks funny its in the night with a flash
Next plans - catch can,
silicone tip/ hose
18'' Alloys
S/S downpipe & sport cat/ exhaust system
new Smic + vent the arch
ko3s hybrid turbo
Remap- now, not sure if i have the 'older' agu requiring the ecu to be removed & chipped, i do have an obd port, i thought it could just be mapped through that, if i do have the old type, is it an easy enough process to change the ecu so it can be mapped through the obd port
Can anyone reccomend the best place Nearest to Romford Essex that do a successful 'Ecu out' chip (if thats what it needs) remap job on my old AGU for cheapish ?
Sorry its prob such an easy simple question to most of you, but which one is temp sensor ? horizontal or vertical, look like they are both connectet to coolant
20150228 133905
20150228 133913
20150228 133926
Vertical for dash and ecu mate
I fitted the new square 4.pin Temp sensor, cleared fault code, will see if fault code has dissapeared next time i check, this is the one i got -
http://www.ebay.co.uk/itm/221332668822?_trksid=p2057872.m2749.l2648&ssPageName=STRK:MEBIDX:IT
Also threw in some new oil with an oil filter change (fancied getting a K&N one)
http://www.ebay.co.uk/itm/180755611342?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Oh yeah i ditched the dirty small twin cone filter i had (not done a bad job up to now) And put in a oem
S2000 paper induction cone, its pot luck which colour you recieve, in my case was the cream v.stack & red paper
looks huge compared to my last one, i know theres varied opinion on cone filters, but this one is fine for me & the car + cheap from Euro car parts + good enough for Prawn lol
Havent got an S3 sized MAF but improvised for now with a spare reducer thing
Resized audi cone
Update on the 'Attempted' Re.map- Revo makes it look like i can have their stage 1 map (listed on there site for my car) through the obd, even though its narrowband 3.8,
http://www.revotechnik.com/product-details/software/audi/a3-8l/12/stage-1/
The local dealer is Auto Specialists in Grays, So i booked it in with them, all the while them saying 'yeah it should be allright, we'll have a go etc'
Dissapointingly the Revo software was having none of it & just confirmed thoughts of ''only way of a re.map is a ecu chip out tune''
Finding someone that does this near to me is difficult, So im just considering options at mo,
Enjoying the car for what it has in the meantime
