Absolutely devastated.
After a good fight with the carriers bolts, which I won BTW, tried my s4 calipers put the wheel back on and had about 5mm clearance.. Give or take.
So I decided to try the calipers with the rotors. Put the rotors on. Fine.
Secure them so they don't fall on me and grabbed the calipers..
Here's where s*** went downhill.
Before the carriers reaches the mounting holes the carrier hits the rotor, which means the bloke that sold me those as s4 carriers for 345mm rotors either tricked me or didn't know what he had.
My guess is they are for 320mm rotors.
Back to hunting carriers again..
Anyone knows how to spot the difference between 320mm and 345mm carriers?
Rotors on.. Got so mad after this I even forgot to snap the clearance with the wheel on..
Sorry to hear that Pal.
If you dont get enough responses, be sure to put it up as a post in the main section.
, think the reason they did this was because they couldn't diagnose the pcv valve being knackered & shat themselves thinking it was a bigger problem.
