Finally went looking for the cause behind a vibration between 80-90mph. Changed the 2 back wheels hoping it was just a buckled alloy and thankfully it was! have her sitting on odd alloys for the moment until I get it sorted!
Drafted up this cup holder and then 3D printed it. It sits in the coin/pocket next to the cigarette lighter.
This is version one so hopefully get it to look more oem and will paint it grey or maybe cover with fabric.
Finally got round to fitting the RS4 pedals from the group buy.
Unboxed
Old pedals.....
New pedals fitted, used a heat gun & some silicon spray to fit them (a few obscenities where muttered) ......
A nice little improvement over stock ..... A big thank you to Mike for organising these group buys.
I took the plunge and ordered some new shoes for Missy a few weeks ago. All the bits finally arrived last week so I was able to get them fitted over the weekend. My main concern was potential rubbing, but so far so good!
Before (2003 Avant 1.9 TDI Sport with 16 inch wheels):
Now:
View attachment 105676 View attachment 105677 View attachment 105678 View attachment 105680
Wheels: RS5 Replicas (19x8.5J ET32) on OEM Sport suspension
Tyres: Yokohama Advan Fleva V701 235/35/R19 91W XL
Awesome! So how are the OEM oes actually on? Are they stuck on..hence the use of heat gun?
A few obscenities? I heard through the grapvine it was loads!![]()
Yeah, I think my fears were stoked by some of the 19 inch wheels in the B6 Audizine Wheel thread indicating varying degrees or rubbing without realising that the bulk of them were on significantly lowered suspension.You will definitiely not have any rub issues on stock suspension with your current set up.
I was previously on 20x9 with 265/30/20 so bigger in everyway and still no rubbing at all.
Ok a lot more than a few ..... think I went through the list at least twice.
The pedal rubbers have a lip around the rear that just sits over the pedal very tightly. I used the heat gun to make the rubber a bit more pliable, the brake & clutch were kinda easy to put on the throttle was a bitch due to it's curve & slight tapper.
Well if you call that hard work? If I wanted to do that it would take about two minutes if I dragged it out.What you need to do now is remove all your hard work and fit the Passat fan jets.![]()
You got a part number for the Passat jets?What you need to do now is remove all your hard work and fit the Passat fan jets.![]()
New fuel filter and a uprated fuel pumpSeen this on past forums and not noticed a thread like this on here.
Basically whatever you have done to your b6 today stick it up on here. Washed it, fixed it, modded it, looked at it, took it somewhere...so on.
Anyone??
Nothing yet.. but soon...
Any ideas? Anyone tried this??
Plan is to take down the left side and perhaps also the rooflines..
I've run a wire through the left hinge for a RVC..
Or else it could be the left roof rack sealing?
