210 / 225 Base Engine Differences
jedwa115
Aside from a map difference, was there any changes made by Audi to the base engine when they up'ed the bhp to 225? Cheers
HTC
As far as I know it goes something like this:
Early APY engine - large port, no vvt, larger gudeon pins (20mm).
later AMK engine - small port, no vvt, small gudeon pin (19mm) extra emissions stuff x2 lambda probes etc
Latest BAM - As AMK but with vvt.
Ryan will probably be able to give you anything I've missed.
RichA3Turbo
Moderator
Moderator
I dont think the APY was a large port... Could be wrong though.
Rich
HTC
Good point Rich. I think you are right on that one.
Triple_A
I think that APY has also VVT but it is mechanical and BAM has electrical VVT.
jedwa115
Thanks for the input so far... What does each of these things give the engine?
Assume VVT is variable valve timing and is all about power? Similar to Honda's VTEC? Giving an increased rev limit?
Why reduce the size of the gudgeon pin? More free-reving? Piston head change also?
Port? Improved gas flow? Inc power?
Trying to understand the changes that went on and the reasons for them. Hope you don't mind all the questions! Jon
Ryanc
apy ,no vvt, i have a head in front of me, amk,bam does have vvt.
All are smallport.
vvt is just for emissions.
Ess_Three
[ QUOTE ]
All are smallport.
[/ QUOTE ]
Bingo Ryan...
VVT only at idle...adjusting the intercam timing...nothing like VTEC.
I
imported_hookie
Guest
All remap to as near as damn it tuned so go figure! /ubbthreads/images/graemlins/smile.gif
Ryanc
yep,people have tried activating the vvt ,does nothing.
HTC
Thanks for the help guys!
I'd also like to know whay the gudeon pin sized was reduced.
Jodi
Starsky
So if a BAM engine was fitted to a car with an APY engine's ECU, would it work? Basically, is there really no difference?
Ryanc
no. You would have to change the head.vvt module on bam
Jodi
Starsky
Surely the BAM engine would still work with an APY ecu, but without the vvt working?
Ryanc
Bam is me 7.5 and dual lambada and apy is single .It might run but how well ??
foolish3uk
i remember hearing on a course once that the only difference with the vvt engines was the mapping, but have never been bothered to check it out!!!
Ryanc
The apy's are definetly not vvt.
