Hi I wonder if anyone can Help? Im having a problem with my A4 B6 about a week ago my car broke down and the AA man said it was the ECU as fuse 29 (engine management) kept blowing ,so checked on various forums at symptom's( fan staying on, head lights not working)so I took the old one out and ordered a ECU from ebay and was going to get it reprogrammed. I then read a thread about water in the ecu casing so went and checked mine as it was dark when I removed the ecu and there was about 2cm of water in the bottom of the box (im not sure if the water got into the ecu casing before or after I had disconnected the battery & removed ecu . I removed the relays (219,369,373) and they were full of water. I pulled the relays apart and left them on a radiator to dry as they had no visible signs of damage and dred out the casing (but ordered new relays). when the ebay ecu arrived and battery had been recharged I thought I would out of curiosity just try the old ecu and old dried out relays and replaced fuse 29 to see if it would work when the I connected the battery and the fuse didn't blow I was quite surprised and chuffed but once I tried to turn it over I seen smoke coming from 1 of the coils so I disconnected the battery. when the new relays arrived I put them in and noticed that had mixed up relay 219 and 369 and put them in the wrong way round. I replaced the relays with the new ones but now the will not turn over at all.
Any suggestions would be greatly appreciated
