These things are overly expensive imo...That's what I thought, I've already got them coded open but would like to control it to avoid motorway drone without shelling hundreds on something like the Cete valve control![]()
Nothing. MMI menu and Sunroof inclusion are not supported. Window closing is the best you can get.Hello guys. I have a couple of questions hoping that some helpful fella can answer. I coded my A3 8V FL for rain closing. Menu doesn't show up on MMI, however when I put my hand over rain sensor, windows are closing, but sunroof stays openedI don't get what I am doing wrong.
Thanks for the prompt reply! Should I deactivate menu adaptation on module then, or leave as it isNothing. MMI menu and Sunroof inclusion are not supported. Window closing is the best you can get.
No, it’s needed for the feature to work. Menu is supported on other VAG brands I believe but not Audi.Thanks for the prompt reply! Should I deactivate menu adaptation on module then, or leave as it isI suppose it won't cause any DTC.
Thank you. I won't touch it then. Just an additional question; Is there any way to reduce the horn volume of acoustic lock/unlock acknowledge? I don't have factory alarm so I am using vehicle's horn for lock/unlock beep. However it is too loud for nights.No, it’s needed for the feature to work. Menu is supported on other VAG brands I believe but not Audi.
No. Only thing you can do is activate the MMI toggle menu and turn it off before leaving the car.Thank you. I won't touch it then. Just an additional question; Is there any way to reduce the horn volume of acoustic lock/unlock acknowledge? I don't have factory alarm so I am using vehicle's horn for lock/unlock beep. However it is too loud for nights.
The AWE SwitchPath is £261 atm in the UK, though as when I orderd mine I ordered it from Haz Motorsport on eBay for £234, but there was no stock in the UK so the wait time was approx a month. I cancelled this order and decided to order it from USP Motorsports in America.
I paid $200 + 25 shipping which was £165, and after a bit of import tax it came in cheaper than it would have been ordering from the UK (and I think probaly a bit quicker).
I fitted the res delete first and the valve system after, had it for just under a year now. A bit annoying to press the open button every time I get in the car, I have the button stuck behind the drink holders.. But its very routine and I don't think anything of it.Been looking at this and the apr version which is slightly cheaper.
Let us know how you get on. Been toying with this or res delete. Just worried res delete is more permanent and this is controllable.
Coding changes, yes 100% but not for what you are wanting. The core behaviours of the VC are embedded within its firmware. Hit the trip reset button once and it will pop back up from the bottom of the screen. It will not reset the data unless you push it again while its displaying.@DJAlix would you or someone on here know if there are coding changes possible with VCDS for the Virtual Cockpit?
One item I notice is when you change the side panel away from the car information display, you loose mileage and the trip counter. Is there a way to keep this displayed on all tabs on the VC?
Thanks for the guidance!
Just got my Carista adapter. I enabled lock/unlock beep to my Audi A3 8V Limousine 2013, but it doesn't seem to work. I also enabled the configuration menu in MMI and checked "tone when lock/unlock". Still nothing when I lock my car using the key. Any help?
Not possible via coding only. Rears require a facelift LED cluster retrofit . Fronts require a Matrix headlights retrofit + body works.Hi, i was wondering if it's possible to change the normale led indicators to dynamic with VCDS or ODIS?
I have an A3 sportback 2013 1.8 tfsi 7D
The rears can have a module fitted that delays the outer bulbs lighting in order to create a semi dynamic effect yes. No idea on cost.ah oke thanks, but they can be semi dynamic with an adapter which costs like 60 euro?
Hmmm, looks like my guideHello Lads and Lasses,
Anyone have you Auto Close in the Menu on the MMI? I've done the following and it all work perfectly but no display in the MMI display>
Automatic Rain Closing
09 - Central Electronics
Security Access - 16
Code = 31347
(15) Access Control 2 - Regenschliessen_ein aus = Active (Rain Closing On / Off)
(16) Access Control 2 - Regenschliessen_art = Permanent (Rain Closing Type)
(28) Access Control 2 - Menuesteuerung Regenschliessen = Active (Driver Assist Rain Closing Menu)
Select Long Coding Helper
Select RLFS from Dropdown Menu
Change Long Code to 06A8DDs Dan
Testing:
1) Light Switch in Auto position.
2) Wiper stalk in 1st / Auto position.
3) All windows fully open.
4) Locked car and wait for 2 mins.
5) Spray water on windscreen sensor and bam... windows close![]()
Cheers Dan
How did you program the keyfob to open and close all windows via the keyfob?New 2019 RS3 owner here. Replaced a 2018 Golf R, and I’m having trouble making some of the same coding changes that I was able to make on that car. It appears that some are not possible? While others I may just be looking in the wrong spot. North American Model.
I’ll outline what I’m looking to do/having trouble with and if someone could point me in the right direction that would be great!
1) Enable lock/unlock with engine running.
I’ve gotten this to work but only with the key. I REALLY want to be able to use kessy/the door handle to lock/unlock with engine on. I had it working on my 18 R but cannot for the life of me find the setting on this car for that. (Something to so with terminal 15 I’m assuming).
2) Window/sunroof open/close via key and handle.
This one I almost have. I can now open/close the windows and sunroof via the key, and close all via holding the lock sensor on the door handle. Just need to figure out how to open all via long holding rear of handle (assuming it can be done?).
3) Disable amber front side lights.
I’ve read this can’t be done as it is hardwired in now? I find it very odd they would have wired it permanently in when I could do a FL 2018 R via coding no issue... what do they gain by doing such a thing?
If it is indeed hardwired, has someone posted a pinout of the headlight harness connector to show which pin to remove to disable those?
4) Close MMI screen while driving.
I have also seen reports this is impossible via coding? Is that still the case, even with dealer level tools?
5) Disable rear secondary turn indicators. (So that only dynamic strip blinks for signalling).
Also impossible due to hardwiring? Is there a fix anyone has posted by removing pins/modifying wiring?
6) Finally, I’d LOVE to be able to increase the time limit for auto-resume in stop and go traffic. My car has the feature, and it works fine, but the 3 second limit is very annoying. 8 seconds or so would be perfect for heavier traffic jams. Not sure if this is at all possible?
Thanks in advance!
Ed
Hey - NAR owner here too. What was the coding on the R to disable the side markers? I have a PFL S3 with the LEDs, but that’s one that annoys the life out of me and have yet to find. That and having no gear indicator in drive (D1, D2 etc.) in DIS like the RoW VAG cars. It’s got to be somewhere in module 17 but no idea where.New 2019 RS3 owner here. Replaced a 2018 Golf R, and I’m having trouble making some of the same coding changes that I was able to make on that car. It appears that some are not possible? While others I may just be looking in the wrong spot. North American Model.
Thanks in advance!
Ed
Hi DJAlix this link does not let me open. I really want to get access as your name is a major KEY lolFor those who are interested here is the VCDS Document:
https://www.dropbox.com/s/vqxra6zs2wu69in/VCDS Adaptations and Codings.pdf?dl=0
*Just updated to version 2.1 - in order to correct an error.
Document no longer existsHi DJAlix this link does not let me open. I really want to get access as your name is a major KEY lol
Same here! How do you make the window close from remote?New 2019 RS3 owner here. Replaced a 2018 Golf R, and I’m having trouble making some of the same coding changes that I was able to make on that car. It appears that some are not possible? While others I may just be looking in the wrong spot. North American Model.
Thanks in advance!
Ed
Unless you are in the process of retrofitting “adaptive” lighting hardware you cannot just code this feature to work.Hello guys. I need your help.
Sorry if this has been asked already but I looked into this thread and I could not find this question so here it goes:
I want to activate the "bending light/dynamic cornering light" for my Audi A3 8V with AFS Xenon.
I am not talking about bottom fog light or the bulb inside the headlight but the xenon projector that moves with the steering and does the dancing when you turn on you car.
Does anyone knows how to activate this via VCDS?
Thanks guys
Oh c**p. So there has to be an adaptive lighting hardware? I mean on the list with options for my car there is "Audi Adaptive Lighthing" but no option in the MMI. Maybe the dealership scr***d me..Unless you are in the process of retrofitting “adaptive” lighting hardware you cannot just code this feature to work.
well yer, if you don't have the needed hardware its not gonna work.Oh c**p. So there has to be an adaptive lighting hardware? I mean on the list with options for my car there is "Audi Adaptive Lighthing" but no option in the MMI. Maybe the dealership scr***d me..
If you don't have the feature from the factory then you don't have the hardware as Audi don't give stuff like this away. If you really want to check then look for a part number on a lighting cluster and google it. If you bought the car based on advertised spec and the car is missing something then you need to have a chat with Audi or whoever you purchased it from.And how I check if I have the hardware?
