8V VCDS Mods
Would need more information to be able to investigate this, namely an auto scan.
Here is the auto scan
Audi A3
Year: 2015
Body type: Saloon
Engine: CNTC 162 kW (220 HP) 2.0 l
Mileage: 86495 KM
01 Engine
System description: 2.0l R4 TFSI
Software number: 5G0906259A
Software version: 0405
Hardware number: 06K907425B
Hardware version: H13
ODX name: EV_ECM20TFS0205G0906259A
ODX version: 001007
Long coding: 0A1D00124426000F2000
02 Transmission
System description: DQ250-6A MQB
Software number: 0D9300011S
Software version: 4312
Hardware number: 02E927770AQ
Hardware version: H52
Serial number: TFK01311180210
ODX name: EV_TCMDQ250021
ODX version: 001001
Long coding: 0014
03 Brakes
System description: ESC
Software number: 5Q0907379AA
Software version: 0457
Hardware number: 5Q0907379G
Hardware version: H31
Serial number: 6331300000036A
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 033001
Long coding: 13FF6A9234200A6D037B030081C629C8562C50C0C08194F7024100588608
08 Air Conditioning
System description: AC Manuell el
Software number: 8V0820047E
Software version: 0052
Hardware number: 8V0820047E
Hardware version: H11
Serial number: 00000000036106
ODX name: EV_AirCondiFrontManAU37X
ODX version: 008018
Long coding: 03000004100000000000000000000100
09 Central Electrics
System description: BCM MQBAB MNA
Software number: 5Q0937085S
Software version: 0124
Hardware number: 5Q0937085S
Hardware version: H16
Serial number: 00011332200145
ODX name: EV_BCMCONTI
ODX version: 012001
Long coding: 04141E42C041227545C04004511007A0001A800000000000000000000000
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655J
Software version: 0820
Hardware number: 5Q0959655J
Hardware version: 009
Serial number: 003GCR000SXX
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002136
Long coding: 9DCCFCC0000000005000001AC24800000065
16 Steering Column Electronics
System description: Lenks. Modul
Software number: 8V0953521CB
Software version: 0110
Hardware number: 5Q0953549C
Hardware version: 002
Serial number: 26111308490195
ODX name: EV_SMLSKLOMQB
ODX version: 017001
Long coding: A018
17 Dash Board
System description: KOMBI
Software number: 8V0920960B
Software version: 2220
Hardware number: 8V0920960B
Hardware version: H02
ODX name: EV_DashBoardVDDMQBAB
ODX version: 008031
Long coding: 0BFD0009ABA0CF050201BE00180000
19 Gateway
System description: GW MQB High
Software number: 5Q0907530Q
Software version: 2163
Hardware number: 5Q0907530M
Hardware version: 212
Serial number: 29111310800374
ODX name: EV_GatewConti
ODX version: 010015
Long coding: 010100082E085A00DB00020C1C0F00000001010000000000000000000000
Subsystems:
System description: E221 - MFL
Software version: X011
Hardware version: H01
Serial number: 19 05 2011 KV832
Trouble codes:
No trouble codes found
22 All Wheel Control
System description: Haldex4Motion
Software number: 0CQ907554D
Software version: 7076
Hardware number: 0CQ907554D
Serial number: HA1-00019.09.1300011270
ODX name: EV_AllWheelContrHA1VW37X
ODX version: 002001
Long coding: 0003
42 Door Electronics Driver Side
System description: TSG FS
Software number: 5Q0959593E
Software version: 0041
Hardware number: 5Q0959593B
Hardware version: 020
Serial number: 050715BG416645
ODX name: EV_DCUDriveSideEWMAXKLO
ODX version: 006003
Long coding: 00301B205C00040000001002
ODX version: 006003
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144P
Software version: 1043
Hardware number: 5Q0909144P
Hardware version: 123
ODX name: EV_SteerAssisMQB
ODX version: 010031
Long coding: 8102
52 Door Electronics Passenger Side
System description: TSG BFS
Software number: 5Q0959592E
Hardware number: 5Q0959592B
Serial number: 030715BG301222
ODX name: EV_DCUPasseSideEWMAXKLO
ODX version: 006003
Long coding: 003413205C00040000000002
ODX version: 006003
Trouble codes:
55 Headlight Regulation
System description: LWR-ECU
Software number: 5Q0907357
Software version: 0080
Hardware number: 6R0907357A
Hardware version: 005
Serial number: --------------
ODX name: EV_HeadlRegulVWLWRMQB
ODX version: 001110
Long coding: 012E000101000000
5F Information Control Unit
System description: MU-S-S-US
Software number: 8V0035844
Software version: 0626
Hardware number: 8V0035844
Hardware version: 012
Serial number: A7A00911132605
ODX name: EV_MUStd6C3PASE
ODX version: 002020
Long coding: 01730100FF0A000011220001001A00005F0003140100810002
BB Door Electronics Rear Driver Side
System description: TSG HFS
Software number: 5Q0959395B
Software version: 0025
Hardware number: 5Q0959395B
Serial number: 30111304080771
ODX name: EV_DCURearDriveMINKLO
ODX version: 006003
Long coding: 000D07204000048000000002
BC Door Electronics Rear Passenger Side
System description: TSG HBFS
Serial number: 30111303110780
ODX name: EV_DCURearPasseMINKLO
ODX version: 006003
Hi,
Yesterday I coded "pace car" blinker.
I set (18 and19) / left (16 and 17)
[09 – Centrale Electrique] -> [Security Access – 16] 31347 -> [Adaptation – 10] ->
Leuchte 16BLK SLB35BLK SL KC9-Lichtfunktion A 16 » Blinken links Helllphase
Leuchte 17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 » Blinken retchs Hellphase
Leuchte18BLK HLA60 Lichtfunktion A 18 » Blinken links Dunkelphase
Leuchte19BLK HRC31 Lichtfunktion A 19 » Blinken links Dunkelphase
when I finished coding I checked what are the settings in the others "Lichtfunktion" and i'm curious why everywhere in "Lichtfunktion C" are "Blinken links Dunkelphase"
I don't have active rear DLR
I have one more question.
Does anyone know which channel is responsible for the turn signal in the mirror?
None, goes through door module
A3 8V Facelift Limousine
Is the document created by DJAlix still available ? Last link i found is dead and the document no longer appears in his signature :)
Thanks in advance!
Removed a while ago due to abuse.
Ah, bummer. I understand. I used it a while ago (2015, when i first got my S3) and found it super useful and was looking to see if anything new and interesting had been added to it, since.
Well, thanks for your good work, too bad good things get ruined by people.
Hey, I read that enabling the rear visual parking sensors isn't an option on FL models? Is that still correct?
Oh that's a real shame, can I ask what the most popular things that people get enabled?
Check out my coding and retrofit blog in the sponsors forum section, @vagcarcoding on Instagram or Facebook. Lots of examples.
Hi,
What is "Pace Car" lights? Any chance of a video?
Reactions: Michael Paul shields
Is this possible on the s5 do you know? Is it on all the time or selectable via mmi?
Never been asked to do this on a new MLBevoII platform car so not sure.
If possible then it’s on all the time for turning signals, alarm system notifications and hazard lights with no MMI control.
Ladies and Gents, need a favour if possible.
Would anyone in or around north London, who has thew following vehicles, equipped with the Audi Technology Pack, be willing to let me connect to your vehicle in order to test my new software based (genuine OEM Audi) Video in Motion solution. I am only looking for the following A3, S3, RS3 vehicles:
  • 2017 (still needed)
  • 2018 (no longer needed, volunteer found)
  • 2019 (still needed)
Currently these vehicles require that additional and costly hardware be installed in order to activate Video in Motion. I have a new software based solution which has been tested on my own vehicle, with the most up to date 2019 MMI firmware, however my MMI hardware has been superseded so further testing is needed and I have no 8V vehicles booked in for a while. Will to swap my services for the brief use of your vehicle :)
(I am also looking for A4, A5, Q5 and Q7 vehicles of the same years and Techpack for testing)
Reactions: AlS3BE
Genuine OEM Audi??? Really.....
You have never heard of Genuine OEM software?
I have never heard from Audi AG that they will be implementing/rolling out a software pack for VIM. Will ask my collegaes at AG if they know about this.
And as you know i have also access to the latest software etc.
But this is an interesting development. Keep up the good work
I think you need to read my text again. MY solution uses Genuine Audi OEM software, IE no hacking, no 3rd party updates etc.
Sorry misread.
Will be following this. If you need remote access to cars i can arrange that for you.
Sorry misread.
Solution cannot be completed remotely but thanks.
Just an FYI, VW Group do offer an SVM solution for VIM but its for emergency and service vehicles only and can only be implemented at the factory build stage of a vehicle.
Reactions: RJ-8V
2018 vehicle found. Still in need of 2017 and 2019 cars.
Reactions: sentinal13
does anyone know what this code is for ? (S3 2017) this is the default and unchanged by me..
I was actually looking to reduce the entry time before the alarm sounds which I cannot find..
Code
@DJAlix more than happy for you to use my car which is a Sept 2016 production date FaceLift
Thanks fella. Needed 17, 18 and 19 vehicles tho... which have all been tested thanks to the forum.
For the benefit of Mr @949 each member that allowed me to test on their vehicles received more than £100 of works in exchange for their time.
(Check out the Magride thread for contex)
Reactions: josedebardi
Another example for Mr @949 ... Mr @jrumball here came to visit me after trying to retrofit Active TPMS. I did charge him for the basic coding but I had to correct his physical installation and also took the control module out of my own vehicle to use in his as the unit he was supplied with needed bench works to get it up and running. So a brand now control module in exchange for his and a good hour of professional installation for free, because as a forum member I wanted him to go away happy.
(See Magride thread for contex)
Reactions: oli356, AlS3BE and stote
I'm happy for you to work on mine S3 2017, but I am a little far away in Leeds, I do have my own VCDS if this needed and we could do a remote session ?
Many thanks but for the testing I was conducting I specifically needed vehicles manufactured in 2017, 18 and 19 due to hardware changes.
You had my 2019 S3 last night. Would you like me to bring it back at some point? More than happy to help as you know I want the VIM to work.. :rockwoot:
Was great meeting you and your car last night. Hope your still liking the MagRide calibration :)
Unfortunately your vehicle does not have the Technology pack which is needed for DVD, SD Card and USB based video in motion. I am working on a method for the other systems and will 100% invite you back over.
Reactions: FeDx_
@DJAlix are you able to provide a solution for manually opening/closing exhaust flaps? e.g. when it's in efficiency mode have them closed but open in individual/dynamic?
I'd be very interested in this if so
Reactions: HertS3
