Silky-S3
Is loving his new 8V S3!
- Joined
- Jan 30, 2009
- Messages
- 1,401
- Reaction score
- 345
- Points
- 83
won't work, each module has it's security number
Yep, I know. Hopefully Ross Tech will get it mapped soon.
yes ! the lane assist is driving me crazy
Acoustic (Alarm Beep) on Lock/Unlock - Can this be done with the standard alarm system or do you need any optional extra? I wasn't aware you can have the 'beep' noise when the car is armed. If so this would be a neat feature.
Can be done as standard, no other options needed
Acoustic Lock Menu - can someone explain more about this?
Adds a extra menu to the MMI under the car settings, to turn on/off the alarm beep without using VCDS
@c.grex - I didn't think this was something possible to have if you don't have any form of sensors built into the tyre/wheel. Any aftermarket pressure requires this and it sends details to a little module where you can see the figures.
No need for extra sensors, just does it through the ABS system.
@Silky-S3 - what is the ACC auto start?
When the ACC starts the car moving automatically (i.e. in a que)
I found the menu to cancel the gong after 15 seconds. and maybe even the menu do desactivate the desactivation of the lane assist if you release the wheel.
Asked my dealer which is a friend for the security code but he doesn't seem to know how to get it
If I was parking in a multi-story car park for example I would always go in to a parking space front first and the system would start beeping as I got close to edge wall. But I can see that and don't need sensors to tell me it's there. It's not quite so easy to see something behind you which is when the sensors and/or camera would be useful. But if I can turn the front ones off then I would be happy.why would the thing been beeping apart if there is clearly an obstacle in front of you ?
anyway there is a button you can push to deactivate the parking sensors
If and when I decide on my new 8V I would quite like to include the reversing camera in the spec. In order to have this I have to include the option of Front and Rear parking sensors, but there is no way I want the front parking sensors beeping at me when I am parking forwards in a parking space. Does anyone know if the beep from the front sensors can be switched off using the car menus or by using VCDS. I would be quite happy with just the rear parking sensors and the reversing camera but this does not seem to be an option I can order.
Vcds has been discussed at the start of the thread. If you read the first couple pages it would give you a better idea.
No it hasn't, it just says coding, which I understand that, BUT is it software that's added into the car or separate on a laptop as ppl have stated you access it on the mmi so is it on the mmi or do you load software to the car, some of us haven't owned an audi or have a clue about all this stuff that can be done
In this situation the front sensors would not activate. The sensors (front and back) are triggered by either putting the car in reverse or hitting the button on the console. As also mentioned, you can change tone and volume for front and back sensors independently.
So does anyone know deffinitively how to make the rear tail lights drls?
Anymore anyone? I'll keep this updated as I come across/work out more![]()
Hi Silky,
Do you know if it is possible to add the time as an option in all the DIS menus like you did with the Oil Temp? It shows date but not time.
I love needle sweep if it's in there why don't the dealers or manufactuers add it on anyway??? I can't understand why they wouldn't enable it
What is the code for needle sweep?
Yes mate, got the code for 09, but really need it for 03 ABS. Ta
HOW DO I DO THIS:
- DRLs - make tail lights permanent or not (rear DRLs)
I think that if the tail lights were permanently on with the DRL's the car would look so much better!!
Just been looking at another forum...
GOLF MK7 VCDS TWEAKS - GOLFMK7 - VW GTI MKVII Forum / VW Golf R Forum / VW Golf MKVII Forum
and post #20 says the code for the ABS module is: 40168
The code is 40168.
