What have you done today?
I only fit hepu waterpumps, they have metal impellers
How do you find them? Usually metal impeller water pumps leak…. They look like fairly good quality, but general consensus is fit an OEM one. This is what most engine builders do including Badger5
Put one from a continental kit (contitech) can't remember what make specifically year and a half ago so far so good
Sent from my SM-G975F using Tapatalk
Reactions: S3AMJ
Personally and from experience metal impeller pumps have a tendency to leak... particularly through the shaft...
While OE pumps do fail this is generally down to not being swapped out on a belt change and plastic will fatigue over years rather than miles (same as rubber will)...
Pattern part plastic impeller pumps can be a lottery... I have personally only ever used an OE water pump (both on the 20v and now the VR) as they do just work... as long as you factor a change of pump in with a belt change then there should be no reason to have a problem with a decent plastic impeller pump...
Reactions: MPH
I installed a Hepu in 2016 on the AGN, its now 2021 no leaks yet and that cars cambelt service is due now. I also purchased one for the AGU 2 weeks ago as im doing that vehicles cambelt service first (i dont know when or if it was ever done).
The oem waterpump on the AGN had a metal impeller and i was the first owner to actually change the waterpump on that car, pics are somewhere in this thread. it looked like something from the titanic
IMG 20210714 1833591
IMG 20210714 1833531
IMG 20210714 1833111
I only use the Hepu ones as its German Made and TUV approved, and they have some pretty strict standards when it comes to using aftermarket parts. So i always try to install TUV approved parts where possible.
Reactions: MPH and S3AMJ
New rack, ecp gave me the wrong inner rods, had to reuse the old ones.
Reactions: MPH
So why I had all the lower dash apart for the I.C.E wiring! Thought I would add my 12-volt power supply as having already removed the cigarette lighter in favour of a dual USB phone fast charger/voltmeter, nice and discrete in the driver's side lower dash cubbyhole part was from an A8 D3 wired directly to the old one that the phone charger replaced, purchased some quality electronic cable and the corresponding plug a small mod but I am pleased with it great for a tyre pump hoover or any other old skool attachments.4D4925071AA8 D31JO 972 753 2ClosedOpen
Reactions: yoursixx, Dohcwp, s3mad_dude and 1 other person
So why I had all the lower dash apart for the I.C.E wiring! Thought I would add my 12-volt power supply as having already removed the cigarette lighter in favour of a dual USB phone fast charger/voltmeter, nice and discrete in the driver's side lower dash cubbyhole part was from an A8 D3 wired directly to the old one that the phone charger replaced, purchase some quality electronic cable and the corresponding plug a small mod but I am pleased with it great for a tyre pump hoover or any other old skool attachments.View attachment 241704View attachment 241705View attachment 241707View attachment 241708View attachment 241709
Very neat! I like that
Reactions: MPH
Oooh me too!! OEM++ :cool:
Thanks dude! The ice build is coming along in leaps and bounds gone for a 5 channel installation all new wiring all round oem++ style p.s you was correct the JL grill needs some modification to the hatch as the closing mechanism is in the way
Reactions: s3mad_dude
So i have been quiet lately but busy with alot of things at once, the AGN needs to have the torque converter replaced, not looking forward to doing that job so that car is not running at present, Did the cambelt on the AGU and still need to replace the metal coolant pipe as well as refresh the suspension as its a spongy affair going on there.
Restored a 2005 nissan 1400 ute that was in an abysmal condition
14001
1400 3
1400
recovered the recaros in marine vinyl, im not a 100% happy with the finish but its looking alot better than the broken leather that was on there
Recaro
Recovered
finally tested the dipping mirror for the AGU, another tucson mirror same as what i installed in the AGN and what @Tuffty also sourced
Mirror 2
Converted a set of tatty xenons into halogen (will be running dual led bulbs on there
Xenon1
Xenon 2
Still need to source an airbag again for the FBSW thats going in the agu as well as install the double din console and headunit
Reactions: tcg, hydro s3 and MPH
Finished refurbing the original 1997 slate grey centre console in slate grey original rubberised Audi finish and volcano mica View attachment 239490View attachment 239491black metallic added a handy twin-port USB fast charger/voltmeter with on/off switch.
I need to do this to basically all of my interior plastics! Did you write a thread on this?
Finally logged back in after a new pc build and a hell of a year. Things are once again moving forwards car wise and hopefully in a couple of weeks the grey one will be finished and moved on with all the original spare parts and a nice new paint job [and faultless wings thanks TJ!]
I was looking at selling the black one up too [RS3 funds] but due to the amount of previous owners i honestly think that i would get lowballed on her, even after the full rebuild etc etc, so im keeping her and most likely gutting and rebuilding again with forged rods, hybrid turbo and so on. The wife has a 320d M-sport and even tho its nippy and comfy its just not a touch on the S3.
Reactions: Tj 0785 and MPH
started working on modernising the agu interior a bit. still struggling to pull the skc from the immo 3 s3 cluster i want to install. vag tacho cant do anything and eeprom rom reader keeps saying cant find ecu
IMG 20211024 173744
Reactions: S3AMJ and MPH
Amazing turn out! Doubt we have that many 8L’s over here to do a group meet!
alot of passionate 8l guys and the group has been growing alot these past few weeks so more of these runs are definately planned, atleast one every month end.
We had another successful Run on Saturday, We stopped at one of the Audi Dealers before embarking on a run around the mountain, i took both cars, my wife drove the N/A one, a larger turnout than before and yet some of the guys had other commitments so the next run will definately be bigger again.
IMG 20211204 091323
IMG 20211204 093341
My 2 cars are on the right
IMG 20211204 110331
IMG 20211204 110338
IMG 20211204 113520
Reactions: MPH and hydro s3
So my Turbo decided to kick the bucket just after our last run, and the initial goal was to recon the turbo and keep everything as it was as i was happy with the car in its current state but every turbo repair shop has been bullshitting me and i just got tired of it, and decided to go the k04-001 route. should have a little more headroom if i decide to start hunting for power in the future.
IMG 20220114 WA0017
IMG 20220114 WA0020
IMG 20220114 WA0023
Reactions: MPH
Our first Major run of the year, car wasnt too happy with the mountain pass and my gearbox mounting came loose, did an emergency repair at the destination when i realised something is wrong. Turbo is still standing, really need to make effort and pull the transmission on that car to see whats wrong there.
IMG 20220326 100615
IMG 20220326 100620
IMG 20220326 095256
IMG 20220326 100625
IMG 20220326 100713
IMG 20220326 100720
IMG 20220326 102725
IMG 20220326 102728
IMG 20220326 113536
IMG 20220326 113544
IMG 20220326 113815
IMG 20220326 113818
IMG 20220326 121435
Reactions: S3AMJ, hydro s3, crispynz1 and 1 other person
nothing interesting lately, havent been on any runs since march, one of our club members also passed away abruptly
i Purchased a Corsa Ute 1.8 Sport, needs a bit of work but ive always wanted one of these especially a 1.8 sport with all the extras, and it was a bargain
278205891 4890896524361666 8793043392594197664 n
a jeep reversed into my one 8l
IMG 20220629 155745
IMG 20220629 155813
Bought rear main seals for both cars, Turbo should be easy since the gearbox is out already, am dreading to drop the gearbox of the N/A again though, they only had one elring in stock so hopefully the Topran seal isnt crap quality. plan is for the elring to go into the turbo and the topran in the N/A
IMG 20220601 101421
bought some 1st gen Leather R8 Seats for a steal, not sure what im gonna do with it yet
These seats
R8seats
They are in pretty good nick and still firm,also feels much lighter than 8l recaros
IMG 20220702 172047
IMG 20220702 172053
forgot to post these but the turbo is back on its wheels, just need to be take for a test drive with the new gearbox
did the rear main seal
IMG 20220820 140212
New coolant reservoir
IMG 20220821 133725
reinstalled the box
IMG 20220827 152348
discs does need to be skimmed though
IMG 20220910 150413
Reactions: MPH, S3AMJ and hydro s3
went to the mountains for a few days of tranquility
IMG 20221108 110538
IMG 20221109 190612
IMG 20221109 183532
Modified my mates instrument cluster this week as he is doing a complete rebuild of his car literally from engine to bodywork and interior.
IMG 20221121 173959
IMG 20221201 200913
Reactions: SoljahofSensi, hydro s3 and MPH
Today I mostly tested the 3D printed Stargate I am building....
Quite momentous given I have spent almost every day for the past few weeks printing parts for the damn thing!! :)
Recently the pipe leading to camcover pipe snapped. Bought a bunch of replacements sfs vacuum pipes had some forge ones never fitted had them changed, got the car back, then the dipstick snapped was prob the original, got that fixed. Still barely driven the car, idle seemed off and eventually the eml came on, scanned came up p0171 think, Lean code. Got a smoke test for the 1st time, was leaking from a plastic bit under manifold all the new bits clamped onto lol. Need to find that now as didn't want to go catch can route.
So I was on a headlight switch quest and still am I noticed most all of them have led failure so far due to age I thought but cracking many open it appears to be a lot of them have smd resistor issues so purchased some replacement leds and resistors damn they are small for my poor eyesight on that note I went about purchasing just out for the fun of it! a MK 5 polo 6R switch surface mount LEDs and much more recent in time and modified it to fit the 8L fascia after sometime later I managed to come up with this it's not perfect please excuse the night shots but thoughts welcome.
Reactions: hydro s3 and s3mad_dude
Stargate update....
I finished the stargate project in the summer last year....
407849856 10161758808974874 8904465897701701019 n
All works pretty well but I do need to do some fettling on the glyph ring as its not as smooth as I would like...
I have since done a fair few other projects although at this time not really finished many as while printing stuff is easy enough and painting is also not a massive issue the post processing of FDM prints is the biggest ballache of all with lots and lots of sanding and filling etc to get the prints looking right...
PXL 20230515 201327522
PXL 20230608 205533565
PXL 20230716 095153165
PXL 20230901 221336684
PXL 20230902 090843281
PXL 20231012 182552258
PXL 20231007 190002135
PXL 20231029 172730029
PXL 20231107 230809892PORTRAIT
PXL 20231121 220307151
....one day I do plan to get outside and make a start on prepping the unfinished models but in the mean time I have started another fairly big project...
PXL 20231125 132157028
PXL 20231201 143813549
PXL 20231210 110920557
PXL 20231210 213734345
PXL 20231225 200152067
PXL 20231228 111831807
PXL 20240104 171250629
PXL 20240102 191135696
Just a full size T-800
  • Wow
Reactions: Stickystuff, s3mad_dude, voorhees and 2 others
came across a crashed TT QS on marketplace, SA only got 85 of these, the breaker yard didnt want to sell me and my mates the complete car, they also really didnt know the value of the car they were just under the impression it was just a modded TT, so we decided to just purchase the valuable parts from it, i ended up getting the Alloys which are really really rare and my one mate took the Recaro pole positions which was a steal for R5000 which is about 208 Pounds, I took the wheel for about 310 Pounds, and they look like they just need a descent refurb and the tires are shot though, thats probably the reason why he crashed lol
Reactions: yoursixx and MPH
I found out that my 19mm open wrench is worn out and closer to 20mm now. I am dropping the sub-frame, gave the ball joints a good spray with a penetrating oil. I just couldn't get a grip. Measured the gap.. 20mm. Woohoo!
I had to cut the aircon condenser off the alloy main radiator due to the dreaded galvanic corrosion between the mild steel bolts and the alloy one it has only been on for five years with great caution I managed to drill and tap some fresh threads a right pain in the neckBoltsBeforeAfter, to be honest.......
33
10
4K
61
6K
21
