2018 Europe Maps (now available)
Datastorm
I just noticed the 2018 maps are now available to download......except it seems I've now hit the 5 download limit on my 2015 A3
Not all heroes wear capes, but if anybody can grab the 2018 UK map and host it somewhere I'd be eternally grateful.
The Challinor
Aren’t the updates hard coded to your My Audi account and your car? Not sure you can share them from another source.
Reactions: GW1
Matty_S3&S5
For all our Oceania members, Australia (and NZ) 2018 maps are up for download too :)
Rob2k68
Well-Known Member
Thanks for the heads up.
Hosting is of no use without licence renewal there is some sort of date or counter hard coded in your MMI.
Sent from my iPhone using Tapatalk Pro
Lawrence Ellul
how can i download the maps? Cant find the option in the MyAudi personal account. My car is a 66 plate A3 with SD navigation
glospete
Unfortunately you can’t use these download maps. With SD nav you need to buy a replacement card I’m afraid.
kevpuk
OK, so probably being dumb, but I downloaded the whole 13+GB file, stuck them on SD card, but car does not seem to recognise?
Any tips on the specific file structure needed or similar - haven't had much searching as always end up with results about SD based navigation :(
cemerson
You should just be able to go to the update section in the MMI, point it at the SD card with the files on, and it should pick it up.
Am I right in thinking the FL car updates the nav over the air, or have I completely made that up? Don't want to download everything if not necessary...
B5NUT
Well-Known Member
How did you format the SD card? Also are the files at the root level or did you put them in a folder on the SD card? It should look like this
JDHOWELLS
Yep - I updated mine on drive to work
deangelj
Are you sure? I see a line item, but when I download I just get the 2017 maps (the line below). Have you got 2018 Aus installed?
thanks
allanmb
Really? How do you get it to update over the air? I updated mine via SD card last time but would much rather just do it OTA
kevpuk
Yep, that is what I had, although there was also other stuff on the root level......turns out it is the SD (microSD in an adapter) that is playing up - it cannot be formatted, even with specialist tool from SDcard.org, and what is on there cannot be deleted....I took a 128GB card out of my camcorder and used that and it was fine!
The Challinor
In the mmi menu one of the options is to download online straight to car. Simple as that.
Does that work over the built in 4G connection then on the FL?
The Challinor
Lehn
Not like Audi to be giving out all that free data
I was only able to choose 3 updates when trying to update through LTE. (E.g. Denmark, North Germany and East Germany). Now all the other countries are greyed out. SD Card update it is.
The Challinor
Certainly does, so simple. Looks like many owners have not worked this out yet?
Yep, looks that way. Should have done that on the PFL.
oli356
I updated to the 2018 UK maps last night, I only updated as I bought my S3 a couple of months ago and at the weekend traveled home on a road that the nav didn't recognise, hopefully now it does.
I downloaded the 25 GB or whatever it was and put it on the SD card and updated, however... I wasn't sure if I could just exit the car (I was at home parked up), would I need the engine turned on to keep the MMI turned on? I ended up just sitting in the car for 1 hour while it updated clicking buttons every now and then .....
azibux1
If you turn the car off, it will carry on where it left off when you restart :)
oli356
Ahh OK great. It said about not removing the sd card so I figured turning the car off wouldn't be good either, didn't want to risk corrupting the nav system or something!
Thanks for clarifying.
Daveotto
Moderator
Staff member
Moderator
Including me
In the uk I was able to select every European country
Great as I am downloading updates for the whole of Europe
Nope, so gonna fill my boots with whole of Europe map updates now
Trevolly
Can I ask how I download the map package from the myaudi website as when i select either complete package or GB maps and then prepare package it immediately offers a file with the extension of .jnlp which i can't seem to do anything with....
oli356
It needs to open with Java, the java app then downloads the actual map data.
If you navigate to the folder the JNLP file is in, right click it and “Open With.” Select the “Java Web Start Launcher” application in the list or click “Browse,” browse to the “C:\Program Files (x86)\Java\jre[version]\bin” folder on your computer and double-click the “Javaws.exe” program file. Browse to the “Program FIles” directory if you don’t see the “Program Files (x86)” directory.
FredrikA3
Quick question. I got Navi through the SD card. I am not connected online. Was told to contact Audi for updates but should I be able to do this free update as well?
glospete
Unfortunately no. If you have SD card nav the the only option is to buy a new card from your Audi dealer. And before you ask, no you can’t copy someone else’s card. It won’t work as they are coded to your MMI.
FredrikA3
That was what I thought. Thanks for the quick response. My map is from 2017 so I’ll wait a bit as the updates is pretty expensive at Audi.
AL_B
This has never worked on my FL. Login details are correct etc. So I ended up going down the SD card route
cemerson
Took me a while to get the download going from the car, but I've updated some of it now. You can only choose 2 or 3 regions at a time to download and it's not really clear how to start the download if you decide to choose additional regions, so I'm just going to download the whole lot to SD and update it that way. Less faff.
Fatbloke
I can login ok to myaudi via my phone but it won't login via the car. Keeps saying incorrect username or password.
Got the car a few months ago, used. Do I need to do a factory reset on the mmi and setup from scratch?
oli356
Possibly stupid question but, on your car do you actually have to enter a username and password? On mine I just have to enter a pin code that I received via email. However it logs me out every time the ignition has been turned off for a while so I have to login again -.-
"Dear Mr xxxxx,
Please enter the following PIN on the Multi Media Interface (MMI) of your vehicle to use Audi connect Infotainment services:
Your myAudi PIN: xxxxxxxx
Have fun using myAudi
Your myAudi Team"
Fatbloke
"Dear Mr xxxxx,
Your myAudi Team"
Where would I find a pin number? It does say username/password or pin number. I don't know what the pin number is.
oli356
I guess if yours asks for a user/pass then it doesn't mater, must be different between the cars... when I had setup my Audi account and login here - https://login.audi.com/login/#/en/GB/login
On the Audi Connect > Overview page it shows the pin.
Ok I see the guide here does say to login using a pin or myAudi login data - https://my.audi.com/content/dam/myaudi/brochures/quickstart/quick-start-guide-en.pdf so guess you just have to use your user/pass... odd how it doesn't work then!
JDHOWELLS
"Dear Mr xxxxx,
Your myAudi Team"
my car somehow gets my login in details from my phone via bluetooth so i never have to login - not sure how that works!!
