2011 A6 PASSENGER FRONT DOOR LOCK
gamby
clevedon
A bit of help required my front passenger will not unlock on remote so ordered new one from ebay set about door removed lock then proceeded to re fit new lock got everything back in and tightened up went to reconnect electric feed could not get it to fit, so removed new lock ( job is a real pain) when i looked at connection car had 6 pins in 1 row new lock had 9 pins in 2 rows, so had to refit old lock and went back on line everything on line is 9 pins will attach pic of car connection help in finding one or part number would help (i know should have looked when i had it out) any help appreciated
think i have found the problem i looked for c7 locks and they have the same fitting my car is 11 plate but with older headlights i thought the 2011 face lift was the c7
this is my fitting it says its for a c7
Unless you confirm part number is same or superseded too, then C7 wasnt a a wise.choice.
Need part number as I advised.
8J2837015C seems to be the part number looks like i have a c7 thought i had a c6 how can i confirm model
chasis 4fh so it is a c6 but door lock part i need is c7 bought myself an odd one
I’ve just looked up that part number on AUTODOC and it shows as being for A3 8p1 and various A4’s. Strange.
The door locks on the C6 were used on many different models, a3, a8 and even the r8.
I know. Just saying that it wasn’t listed as being compatible with a c6 or c7. I have my c6 saved in there and it and it says not compatible with, but lists the above models.
This is the drivers door lock out of my RHD 2008 S6 Avant (so offside right side)
Part number is 4F2 837 016 B. I replaced mine with 4F2 837 016 E
The other side is 4F2 837 015 E.
Hope that helps
Unfortunately Autodoc and most other websites are not that accurate. This is the list of all the models 8J2837015C is used in. Also that part number is not listed for the 4F models just the later 4G (C7)
Upload 2021 1 28 9 19 30
Upload 2021 1 28 9 20 40
Upload 2021 1 28 9 21 36
Upload 2021 1 28 9 22 0
hi have now taken lock out for 3rd time to find new one does not fit but i have now recorded part number F42837015D however i cant find one used so may have to go to audi or put up with it i will give it a good clean and see any help appreciated
That lock was only used on the A6. Does your car have keyless entry?
Upload 2021 1 30 19 27 13
Or you could replace just the faulty el. motor inside the door lock, it costs around 2USD. I did it on my car two years ago and it still works
update: had a bump on drivers side wing got repaired now passenger door working fine
