Hi all,
Apologies in advance for the lengthy post, I just feel it helps to add a bit of backstory and include as much detail as possible.
So the issue I'm having arose shortly after fitting a "Dutchbuild" haldex controller, now this is not a traditional competition haldex controller which would replace the stock module, this actually retains the stock unit and is installed inline between the car and contoller. If I have not explained that clearly enough please visit the link here for more information http://www.vdveer-engineering.nl/index.php/en/products/haldex-controller. Also before installing on the car I updated the firmware to the latest version and downloaded the latest version of the app.
Anyway moving on to the issue at hand, I installed the inline controller on Monday and drove the car monitoring the haldex bias with the software app on my phone and everything seemed to be working fine. To start with I left it in passthru mode which means the inline controller does not alter the signal going to the haldex module so the haldex will behave as it would completely stock. I also tested the lock function and that seemed to work perfectly well too keeping the bias locked in 30/70, 40/60, 50/50 as I selected.
Fast forward to Tuesday, driving home from work I thought I'd give the car a bit of a blast and watch the bias as it changed in real time on the app in passthru mode as I wanted to monitor stock haldex bias behavior before creating my own bias maps as it were (for track use mostly). At first no problems but then I started getting a lot of wheel spin in all gears and the esp light was flashing at me, also noticed the bias showing on the app was no more than around 97/3 even at wot in low gears.
So I scan the car, stupidly I didn't autoscan and save straight away but I had several faults indicated on the ABS, AWD and CAN gateway modules for AWD module, powertrain databus, diagnostic interface for databus, transmission control module (no communication), engine control module (implausible signal). Having done some googling and from talking with dutchbuild themselves it was suggested the CAN gateway needed to re-evalute the network and in order to do this I should recode it with the original coding. I did this and it cleared all the faults bar 2 on the AWD-22 module for transmission control unit and engine control unit. Obviously with the car being a manual the transmission code was odd, so I attempted to recode the AWD module as was suggested in this thread https://forums.ross-tech.com/showth...it!-Need-Help-Recoding&highlight=haldex+01315. Unfortunatley this had no effect even when changing the wsc to non zeros, I also cycled the key after every coding attempt but as soon as I clear the codes on that module they reappear straight away. Here is the autoscan
So I removed the inline controller and carried out another full scan, this time only 1 fault on AWD-22 for 01315 transmission control module fault but again I am unable to clear it without it immediately reappearing. That scan is here
So the question is why is the haldex still looking for a tcu especially since it is back to stock? I have looked in the CAN gateway installation list and auto trans is not checked. What do I need to do next?
For reference here is an old auto scan from prior to fitting the inline controller
Code:
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: TRUZZZ8JXA1900307 License Plate: T77RSW
Mileage: 129140km-80243mi Repair Order:
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 37 3D 42 44 46 47 52 55 56 77
VIN: TRUZZZ8JXA1900307 Mileage: 129140km-80243miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
3D-Special Function -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CEP) Labels:. 07K-907-404-CEP.clb
Part No SW: 8J0 907 404 HW: 8J0 907 404
Component: 2.5l R5/4V TFSI 0020
Revision: F4H03--- Serial number: AUX7Z0I3FNS0PS
Coding: 0113000C180F0160
Shop #: WSC 01236 785 00200
VCID: 6ADBCDA045368F1F19-803E
No fault code found.
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8J0-614-517.clb
Part No SW: 8J0 910 517 HW: 8J0 614 517 C
Component: ESP MK60E1 0010
Revision: 00H60001
Coding: 0610199
Shop #: WSC 64465 001 1048576
VCID: 69D9B2AC4030840710-803C
Address 08: Auto HVAC Labels: None
Part No SW: 8J0 820 043 AQ HW: 8J0 820 043 AQ
Component: J255 Klima 1 Zone 0090
Revision: 00H08006 Serial number: 00000001128652
Coding: 1573893
VCID: 75E1EEDC1C8850E784-8020
Address 09: Cent. Elect. Labels:. 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009592348
Coding: F0061E8380141C80CF18000A1800000000894E875B260A02008000000000
VCID: 489F57283BFA9D0F2F-801C
Subsystem 1 - Part No: 8J2 955 119 A Labels: 1KX-955-119.CLB
Component: Wischer AU354 H08 0070
Coding: 00064784
Shop #: WSC 01236
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH04 0003
Coding: 00149804
Shop #: WSC 01236
Address 15: Airbags Labels: 8J0-959-655.lbl
Part No SW: 8J0 959 655 HW: 8J0 959 655
Component: -r Airbag 9.43 H03 0020
Revision: 93H03002 Serial number: 0036K003NDK2
Coding: 0011634
VCID: 79F9E2EC30903487E0-802C
Subsystem 1 - Serial number: 6332DRB408DA531BY
Subsystem 2 - Serial number: 6342DRB408B3CAA3+
Subsystem 3 - Serial number: 63747RB404CE64A5
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004041
VCID: 41894A0C18C0AC47E8-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8J0-920-xxx-17-MY8.clb
Part No SW: 8J0 920 980 G HW: 8J0 920 980 G
Component: KOMBIINSTR. VDO H02 0480
Revision: D0H02002 Serial number: 2243I002000032
Coding: 0037428
VCID: 35612EDC5C0810E744-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K094070228
Coding: E9831F06510602004101
VCID: 377D24D44604E2F756-8062
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 2K0 907 554 HW: 2K0 907 554
Component: Haldex 4Motion 5003
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 6BD5C8A44ACC961762-803E
2 Faults Found:
01314 - Engine Control Module
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 138
Mileage: 129140 km
Time Indication: 0
Date: 2020.02.26
Time: 16:01:28
01315 - Transmission Control Module
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 138
Mileage: 129140 km
Time Indication: 0
Date: 2020.02.26
Time: 16:01:28
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H02002 Serial number: AUX7Z0I3FNS0PS
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8J0 035 193 HW: 8J0 035 193
Component: RNS-E PU EU H02 0220
Revision: 0000001S Serial number: AUZBZ7J6301194
Coding: 0619757
Shop #: WSC 00976 210 67917
VCID: 67DDB4945624B27706-8032
1 Fault Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 182
Reset counter: 171
Mileage: 126465 km
Time Indication: 0
Date: 2019.11.06
Time: 08:03:52
Freeze Frame:
Mileage: 129140 km
Count: 2602
Clock: 13:32
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 A HW: 8K0 907 440
Component: STS H04 0010
Revision: S0H04000 Serial number: 00000000004331
Coding: 01010101000000000000000101
VCID: 2C570BB88F42512F2B-8078
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8J8 959 801 D HW: 8J8 959 801 D
Component: Tuer-SG H03 0080
Coding: 0004661
VCID: 3E7331F0693ED3BF95-806A
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 8J0 909 144 R
Component: EPS_ZFLS Kl. 239 3501
Revision: 00H22000
VCID: 3F8D4CF46E34DAB79E-806A
Address 46: Central Conv. Labels:. 8J0-959-433.lbl
Part No: 8J0 959 433 B
Component: KSG H11 0080
Coding: 1890300001182D298505489AD637
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 8J0 951 177
Component: DWA-Sensor H03 0020
Address 47: Sound System Labels: 8J0-035-223.lbl
Part No SW: 8J0 035 223 D HW: 8J0 035 223 D
Component: J525 Amp High H04 0160
Revision: PROD_01 Serial number: 00000000005089
Coding: 0246317
VCID: 2541FE9CECA86067F4-8070
1 Fault Found:
16349 - Control Module - Error in Output Stage
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 90376 km
Time Indication: 0
Date: 2016.11.22
Time: 15:35:09
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MAX3.clb
Part No SW: 8J8 959 802 D HW: 8J8 959 802 D
Coding: 0004660
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0050
Revision: 00000001 Serial number:
Coding: 0000024
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0619757
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Reset counter: 171
Mileage: 126465 km
Time Indication: 0
Date: 2019.11.06
Time: 08:03:52
Freeze Frame:
Mileage: 129140 km
Count: 2602
Clock: 13:32
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005086494
Coding: 0011422
VCID: 4683591031EE8B7FDD-8012
End-------------------------(Elapsed Time: 02:05)--------------------------
Code:
www.Ross-Tech.com
Revision: 00H60001
Coding: 0610199
Coding: 1573893
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
Coding: 0011634
Coding: 0004041
Coding: 0037428
Coding: 0000005
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 138
Mileage: 129140 km
Time Indication: 0
Date: 2020.02.26
Time: 12:59:30
Coding: 0619757
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Reset counter: 130
Mileage: 126465 km
Time Indication: 0
Date: 2019.11.06
Time: 08:03:52
Freeze Frame:
Mileage: 129140 km
Count: 2602
Clock: 12:49
Coding: 0004661
Revision: 00H22000
Coding: 0246317
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 90376 km
Time Indication: 0
Date: 2016.11.22
Time: 15:35:09
Coding: 0004660
Coding: 0000024
Coding: 0619757
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Reset counter: 130
Mileage: 126465 km
Time Indication: 0
Date: 2019.11.06
Time: 08:03:52
Freeze Frame:
Mileage: 129140 km
Count: 2602
Clock: 12:49
Coding: 0011422
End-------------------------(Elapsed Time: 02:09)--------------------------
Address 19,1K0 907 530 S,recoded (Installation List),from,E9831F06510602004101,to,E9831F06510602004101,,
Address 19,1K0 907 530 S,recoded (Long Coding),from,E9831F06510602004101,to,E9831F06510602004101,(01236/785/00200),
Address 22: DTCs cleared
Code:
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
Mileage: 117660km-73110mi Repair Order:
VIN: TRUZZZ8JXA1900307 Mileage: 117660km-73110miles
01-Engine -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
VCID: 6ADBCDA045368F1A6B-803E
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 117657 km
Time Indication: 0
Date: 2018.11.30
Time: 12:44:49
Freeze Frame:
RPM: 705 /min
Load: 5.5 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 29.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
Revision: 00H60001
Coding: 0610199
VCID: 69D9B2AC4030840262-803C
Coding: 1573893
VCID: 75E1EEDC1C8850E2F6-8020
VCID: 489F57283BFA9D0A5D-801C
Coding: 00064784
Shop #: WSC 01236
Coding: 00149804
Shop #: WSC 01236
Coding: 0011634
VCID: 79F9E2EC3090348292-802C
Coding: 0004041
VCID: 41894A0C18C0AC429A-8014
Coding: 0037428
VCID: 35612EDC5C0810E236-8060
VCID: 377D24D44604E2F224-8062
Coding: 0000005
VCID: 6BD5C8A44ACC961210-803E
Coding: 0619757
VCID: 67DDB4945624B27274-8032
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 95
Reset counter: 253
Mileage: 111543 km
Time Indication: 0
Date: 2018.03.25
Time: 20:32:07
Freeze Frame:
Mileage: 117660 km
Count: 212
Clock: 16:33
VCID: 2C570BB88F42512A59-8078
Coding: 0004661
VCID: 3E7331F0693ED3BAE7-806A
Revision: 00H22000
VCID: 3F8D4CF46E34DAB2EC-806A
Coding: 0246317
VCID: 2541FE9CECA8606286-8070
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 90376 km
Time Indication: 0
Date: 2016.11.22
Time: 15:35:09
Coding: 0004660
Coding: 0000024
Coding: 0619757
1 Fault Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 95
Reset counter: 253
Mileage: 111543 km
Time Indication: 0
Date: 2018.03.25
Time: 20:32:07
Freeze Frame:
Mileage: 117660 km
Count: 212
Clock: 16:33
Coding: 0011422
VCID: 4683591031EE8B7AAF-8012
End-------------------------(Elapsed Time: 02:10)--------------------------
