Hi all,
First time on a forum, but havin a problem with my s tronic on my s3 8p. Basically it clunks in to first gear from set off and does the same till third gear. After a while it will jump out of gear and i will have to restart the engine. And then when i put it in reverse it comes out reverse gear and the r disappears from the screen displaying no gears. It also acts like its misfiring whilst in low revs which sounds like its the gearbox making it do it.
I had it on diagnostics machine which brought up the following codes:
17252 - transmission fluid pressure adaptation at limit - pressure too low - p0868 upper limit reached.
18223 - pressure control valve 1 n215 short to plus p1815 not a plausible signal.
Thinking its the mechatronic i have took it to ecu testing in derby who checked the mechatronic over and are sayin there is nothing wrong with the mechatronic. Pretty baffled here. If anyone could help me out here... thanks in advance!
