Adammann93
Hello Everyone,
Looking for any ideas on what my issue may be.
last week when joining the motorway when i put my foot down the revs started "surging" (revving up and down when foot on pedal) while loosing power and blowing some white smoke out the back. Pulled on to the hard shoulder managed to get it started but it doesn't stay started for long and was unable to drive it away so got recovered.
The day after i plugged my laptop in to read any codes and got the following (Ignore the MAF that was me unplugging it)
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 G 1247
Revision: --H42--- Serial number: AUX7Z0G4FN3060
Coding: 0000172
Shop #: WSC 06314 000 00000
VCID: 74E769D717BB262607-8020
2 Faults Found:
000665 - Boost Pressure Regulation
P0299 - 006 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 217022 km
Time Indication: 0
Date: 2021.02.16
Time: 16:28:53
Freeze Frame:
RPM: 2272 /min
Torque: 160.0 Nm
Speed: 34.0 km/h
96.33 %
Voltage: 14.46 V
Pressure: 2492.1 mbar
Pressure: 1065.0 mbar
000258 - Mass Air Flow Sensor (G70)
P0102 - 007 - Signal too Low - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 217023 km
Time Indication: 0
Date: 2021.02.16
Time: 17:28:04
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.09 V
Mass Air / Rev.: 872.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: N/A
The garage has inspected my turbo and said its fine and that more investigation needs to be done to find the issue, they cant get onto it yet due to being too busy.
I'm hoping that someone on here has some experience with the issue.
My thoughts... Lift pump in the tank failed? it does start with difficulty but is rough and doesn't stay started for long, almost like it isn't getting the fuel it needs. Doesn't throw any codes though and I cant get back to the car at the moment to do any VCDS logs. I say lift pump as it had a new tandem pump a few months ago for suspected seal failure.
Other thing could be injector seals ?
Any help with this would be much apricated, it would be good to have a few ideas before I go back to the garage.
Coding: 0000172
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 217022 km
Time Indication: 0
Date: 2021.02.16
Time: 16:28:53
Freeze Frame:
RPM: 2272 /min
Torque: 160.0 Nm
Speed: 34.0 km/h
96.33 %
Voltage: 14.46 V
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 40
Mileage: 217023 km
Time Indication: 0
Date: 2021.02.16
Time: 17:28:04
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
0.00 %
Voltage: 12.09 V
Readiness: N/A
