2006 A4 S LINE CAB, PARTS AND ADVICE FOR NEWBIE
razor2812 Nov 13, 2017
  1. razor2812
    razor2812 A4 S LINE CAB, 2006
    20
    HI EVERYONE, RECENTLY PURCHASED THE ABOVE , AND GETTING MORE CONFUSED EVERY TIME I READ ABOUT THE FRONT GRILLE.
    MINE HAS DAMAGE TO THE CHROME GRILLE SURROUND, NO ONE WANTS TO SELL THE CHROME ONLY THE WHOLE GRILLE, BUT I NEED SOME ADVICE ON WHAT WILL FIT MY CAR
    IS THERE A PARTS DEALER ON THIS SITE RECOMMENDED AS I AM ON THE LOOK OUT FOR ONE OR TWO OTHER BITS
    THANKS IN ADVANCE, AS I HAVE NOT HAD TIME LOOK THROUGH THE SITE YET
  2. Avatar
    Google AdSense Advertisement
  3. martin1984
    martin1984 Well-Known Member Team Silver Audi A4 Audi Avant Owner Group TDi
    1,854
    2,288
    Hi there look like you has a se front bumper to me which is good news for you as you have more opitio s for a replacement girll you can get a rs4 look grill that will fit right in off ebay a very nice upgrade and not too expensive
    Sent from my SM-A300FU using Tapatalk
    There is a part request for gen parts
  4. razor2812
    20
    HI, thanks for reply, I'm just looking for like for like replacement, I have repaired the damaged chrome, with some chrome foil tape, cant really see on the pic but it is not a match for the std chrome on the grille surround.
  5. martin1984
    1,854
    2,288
    Cant say ive seem the chrome part alone for sale but worth asking in parts requst or like i said a rs4 honey comb grill for your s.e bumper is around £120/£150
  6. razor2812
    20
    no I haven't, looks like ill have to buy the whole grille, at least it will be a bit cheaper than the s line one that seems to be double the price
  7. martin1984
    1,854
    2,288
    Take a look at this 253256720334
  8. razor2812
    20
    how do I do that does the number need inputting somewhere?
  9. martin1984
    1,854
    2,288
    Sorry yea it a ebay number for a grill
  10. razor2812
    20
    cheers
  11. razor2812
    20
    I'm keeping it std for now, spent a lot on mods on my old celica , but I'm happy with std for now on this car. a bit of cosmetic work and its a mint car.
    might need it tuned or remapped though, its heavy on fuel
  12. Avatar
  13. Just Rob.
    Just Rob. Moderator Staff Member Moderator Team Brilliant Black Team Daytona TFSI Owners Group Team V8 VCDS Map User Gold Supporter Audi RS4 Audi A4 Audi Avant Owner Group quattro S-line owners group Manual
    6,882
    3,513
    very straight forward answer for you chap, yes it is an SE bumper so grille will be a standard non s-line part.
    The surrounds are detachable but not available as a spare part so you would need to order a complete grille assembly, unless you found a cheap used grille with a decent surround and used that.
    As it's a standard non s-line grille there are plenty aftermarket grilles that will make a suitable replacement at a fraction of the cost of a new OEM part.
  14. razor2812
    20
    thanks, do you know if it is easy to remove and replace the chrome surround or does it damage it?
  15. Just Rob.
    6,882
    3,513
    a word of caution , to change the grille you need to remove the whole front bumper , there is no other way i'm afraid so be prepared.
    martin1984 likes this.
  16. Just Rob.
    6,882
    3,513
    as above, bumper off to remove grille assembly , surround can be removed by very carefully releasing the locating tabs located around all the sides, be carefull as they are not really designed to be removed so can break.
  17. razor2812
    20
    had this issue on a previous car, and ended up damaging some solid plastic lugs which clipped to wings, is there anything to watch out for when removing bumper. (I guess this is why a lot of traders want to sell the whole front end complete
  18. Bradderz_1988
    4,000
    263
    Got this grill on my dtm think its an FK ebay one
    Just Rob. likes this.
  19. Just Rob.
    6,882
    3,513
    It can be as easy or as difficult as you make the job, a bit of a long reply to type now chap but look on line or on this forum as there are quite a few you tube vids now that show the removal process much clearer than reading a thread.
    Normally refitting can be an issue with getting the gap even along bonnet etc as the bumper adjusters get seized and you cant raise or lower the bumper to get the gap just right, not a massive issue and can be resolved with new adjuster or just doing a botch with them.
    Anyway , more of an awkward job than difficult.
  20. Just Rob.
    6,882
    3,513
    DTM bumper uses the standard non s-line grille so that grille will fit any SE or standard B7 bumper.
  21. razor2812
    20
    ok that helps, so if I cannot adjust gap, needs new adjusters. ill check you tube, thanks for the heads up
  22. Sturat
    Sturat Member TeamMisano Team V6 Audi A4 Audi Avant Owner Group Audi Cabriolet Owner Group TDi
    109
    10
    If it's the v6 3.0 tdi and you eventually want to change the front bumper with standard s-line you'll have to trim down the intercooler scoops otherwise it won't fit on. If it'd the 2.0 tdi then there's no problem - straight swap
