2005 A4 B7 2.0T Quattro, No boost, won't rev over 4000pm
CharlesB Oct 7, 2018
  1. CharlesB
    CharlesB New Member
    10
    I am trying to help a friend diagnose a fault with his car.
    In the last 4 years it has been running fine with the last issue being a coil pack failure in 2014.
    Issues:
    EPC Light on:
    Check engine light comes back on after clearing codes. (EPC Light never goes away)
    Car has no power, won't really rev, no boost.
    Idle is fine, MAF seems fine (readings look normal on Live Data).
    The following codes come up as soon as you start the car after clearing the codes:
    P0444: - EVAP Purge Control Valve (N80): Circuit Open
    P0033: -Turbocharger or Supercharger Bypass Valve Control Circuit
    P0243 :- Wastegate Solenoid A - No Signal
    P2295: - Fuel Pressure Regulator 2 Control Circuit Low
    P1573: Left Engine Mount Solenoid Valve Open Circuit
    Its almost like the N75, DV etc are not getting power.. (Replaced the N75, but no change)
    Has anyone come across this before?
    These faults all occurred at the same time and constantly come back as soon as the engine is started.
  2. Avatar
    Google AdSense Advertisement
  3. CharlesB
    CharlesB New Member
    10
    Crisis averted.
    It was a 15a fuse next to the 614 Relays in the ECU box, car now boosts well again.
  4. jay1601
    jay1601 Well-Known Member
    1,409
    99
    Had the same issue with my 2.0tdi kept blowing the fuse would go into limp mode with no boost.
    turned out to be a short in the engine mount, unplugged the wiring from the sensor in the left engine mount never had the issue again.
