Hi All, been nearly 10. years since I was last here ! got myself an S4 that needs a little bit of tinkering with to get it right.
I just spent yesterday morning replacing the coolant temp sensor on the car because the temp gauge on the instrument panel doesn't work. It doesn't light up either when headlights are on.
After eventually getting the new sensor in I was disappointed to find the temp gauge still not working.
So I spend's an hour or two on VCDS and run the activations on the instrument panel to find on the needle sweep the temp gauge remained at 50 degrees, it did not move.
After scanning and find communication error with instrument panel I think the fault is with the panel itself, coolant temp shows correctly in VCDS.
Please can anyone recommend a reputable company who would be able to fix the instrument panel as I am concerned that it will come back with different mileage or immobilised.
Thanks in advance,
Mark
Thanks in advance,
Mark
