2001 Allroad problems.
_MarkR_1
Hello.
I have a 2.5tdi. It's been stood for a few years so I intend to change the cambelt, pump belt, water pump, pulleys and thermostat.
VCDS shows a fault on the needle lifter and it shows open circuit when tested.
There is also a fault on the accelerator position sensor.
The air supension light is on in the dash but apart from failing to get to the high position it doesn't seem to sag while parked.
It starts and runs well enough although my Dad always complained about the terrible fuel consumption.
My main concern is the cambelt etc. I've ordered a continental kit and a genuine Audi thermostat.
I'm considering a genuine Audi injector but I guess thats pretty expensive.
Has anyone had any luck with other sources?
I see that I can get a Bosch item from Autodoc (which takes ages these days) but how can I know it is the correct injector?
The air bag light is also on and VCDS shows 10 faults for an internal control module error
There are some other faults but it has has a flattened battery now and again so I'm hoping some of it sorts itself out. :hopelessness:
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 4Z7 907 401 A
Component: 2.5l/4VTEDC G000AG D00
Coding: 01016
Shop #: WSC 02325
VCID: 3B233D4D9A7F79A39A1-4B00
Subsystem 1 - Part No: 00014059
Component: 130 106EC150_1.R75984419182
WAUZZZ4BZ1N142091 AUZ7Z0A1785398
5 Faults Found:
00542 - Needle lift Sensor (G80)
30-10 - Open or Short to Plus - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
00777 - Accelerator Position Sensor (G79)
28-10 - Short to Plus - Intermittent
01318 - Control Module for Injection Pump (J399)
37-00 - Faulty
Readiness: N/A
Address 15: Airbags Labels: 4B0-959-655-AI8.lbl
Part No: 4Z7 959 655
Component: Airbag F2ont+Seite 2002
Coding: 01106
Shop #: WSC 02325
VCID: 0C41AE918F518E1BE3B-5160
10 Faults Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 G
Component: - 2C1A1 D052
Coding: 25500
Shop #: WSC 00000
VCID: 49CF5785C0A3DB3318D-513C
1 Fault Found:
01437 - Control Position not Learned
35-00 - -
Cheers,
Mark
