  2. Dismiss Notice
20" wheels ride quality
Candell Aug 29, 2019
  1. Candell
    Candell Registered User
    144
    39
    Hi
    I have seen a nearly new A6 Avant S Line, I have test driven an S Line with 19" wheels and the ride was comfortable, however the car I have seen has 20" wheels.
    Will this stiffen the ride significantly?
  2. Avatar
    snack-media
    Advertisement
  3. Tendaimwari
    Tendaimwari Registered User
    166
    20s are not that bad tbh. Ride is no worse than my previous s4
  4. Buxton2901
    Buxton2901 Registered User
    1,576
    711
    The ride was much worse in my A4 B8 and that was only on 18's.
    It really not as bad as i expected this to be on 20's
  5. Candell
    144
    39
    Thanks folks
  6. rob0904
    rob0904 Registered User
    326
    24
    I think my a6 ride 20s is better than my ladies a1 on 17s
  7. J10NMM
    J10NMM Registered User
    193
    56
    Had 19's on my golf and the ride was harsh.. Got 20's on the A6 and it's like a dream
  8. A6S_line
    A6S_line AUDI A6 S-LINE 2.0 TDI 140 KW Vcds and vag can pro
    9
    I drive my A6 20 inch bbs just fantastic
  9. fingermouse
    fingermouse thats me
    4,245
    198
    20 on the a6 is better than 19 on the 2002 s3 I had
  10. Candell
    144
    39
    Thanks folks
  11. AndyT306
    AndyT306 Moderator Staff Member Moderator
    999
    487
    really not that bad... i've driven an SE on 18s and it didn't feel much different
  12. Avatar
    snack-media
    Advertisement
  13. Candell
    144
    39
    Thank you, I ended up with a new A6 on 19's due to the awesome deal I got. Took delivery of the car last week, the ride is very comfortable.
  14. J10NMM
    193
    56
    18's will have fat tyres so the ride will be soft...
  15. Essex-man
    Essex-man Registered User
    39
    32
    I’ve just replaced my 2015 A6 black edition with 20 inch wheels for the latest black edition with the same size. Cracking car and love the sporty ride. That said, in comparison to the ride in my RS3 it is very soft.
  16. AndyT306
    999
    487
    it should be, but there isn't much difference, i think the firm ride is primarily down to suspension setup, and most audis are setup hard to make them feel sporty
  17. CHEZ
    CHEZ moderately amusing Supporter
    7,382
    1,672
    I swap from 20" with 265/30/20 tyre to 18" 245/40/18 over winter and the main noticeable difference is wallowing and pitching on the 18's on account to the sidewall height and maybe a touch less grip slightly due to the tyres not being the best.
    I only notice this on corners or roundabouts when I forget that I don't have my 20" inch rims on so soon adapt my driving to suit lol.
    The cornering and grip are far superior on the 20" due to the extra width and very low sidewall.
    It makes the car much sportier feeling and planted.
    The only negative if I am being honest and comparing the 2 sizes are mainly potholes and kerbs!
    Mainly because the 20"s are expensive with expensive rubber and the 18"s are more supple and accommodating with there squishy tyres lol.
  18. I'm Just Rob.
    I'm Just Rob. Moderating or something, Staff Member Moderator Gold Supporter VCDS Map User
    14,820
    6,874
    It's not the diameter of the tyre that decideds the quality and ride , its the tyre sidewall profile and suspension damping qualities.
    The lower the profile of any given tyre in relation to its width will have a noticible impact on ride quality .
    lower profile tyres will by there nature become stiffer than the same width tyre which has a higher sidewall profile.
    The sidewall is a flexible part so acts as a shock absorber , take away some of that ability and you will notice a stiffer ride, run flat tyres are a good example as they have very stiff sidewalls.
    A 235/35 18 will have less give than a 235/40 18 , its not a massive change but still a change and factor in different tyres vary in construction compound ,
    you get my drift.
