2.7t evap system/charcoal canister - anyone clued up on this?
VAG-Slag Jan 23, 2018
  1. VAG-Slag
    VAG-Slag Well-Known Member
    1,840
    437
    I think I have a problem with my fuel system breather, but I don't know enough about how it works to pass judgement!?
    I've previously noticed a slight woosh of air as I open the fuel cap, suggesting it's not venting properly... And also (not sure if it's related) often an odd whistle when I shut the engine off.
    Recently, after a drive in the rain, I noticed a gargling sound from under the car on the drivers side. On closer inspection there was a pipe right under the drives seat (pretty sure it's part of the charcoal canister breather) that was sucking up air, water and what ever else it found under the car!
    I put my thumb over the pipe and there was a proper vacuum there while idling, but I can't imagine why it would be sucking in so much air/water and where it's going!? . .
    Just doesn't seem right - anyone able to elaborate on this at all?
  2. Avatar
    Google AdSense Advertisement
  3. QuattroCalum
    QuattroCalum Well-Known Member saloon Audi A4 Black Edition Saloon Manual
    1,964
    706
    It must have come apart at a connection, it should run to the charcoal canister which is behind the drivers side front wing splash guard. Jack it up and take the wheel off and remove the splash guards ( it’s just a few torx screws) you should be able to follow the pipe work from there and sort the problem.
  4. VAG-Slag
    1,840
    437
    Thanks for the reply...
    Connection where though?.. The open pipe is secured and looks like it's supposed to be there:
    And it must be connected to something at the other end otherwise it wouldn't be sucking up air...
    Unless I'm missing your point?
  5. QuattroCalum
    1,964
    706
    That’s why I suggest removing the splash guard and see what’s missing or where those pipes lead.
  6. aragorn
    18,738
    900
    thats some sort of drain from the carbon can. I dont think it should be sucking stuff up.
  7. VAG-Slag
    1,840
    437
    Thank makes more sense... My concern is that vacuum can only be coming from the inlet and that it's sucking stuff straight into the engine!?
    I'll trace it back and see what I can find
    mojocvh likes this.
  8. QuattroCalum
    1,964
    706
    Could be the one way valve has failed allowing vacuum from turbo inlet pipe (if it’s similar set up to 1.8t) the solenoid should purge tank gasses to tip, there’s a one way valve just after the solenoid.
  9. VAG-Slag
    1,840
    437
    The car is on axle stands at the moment anyway... I'll have a poke about on the weekend!
    Thanks for your input guys *thumbs up emoji*
  10. QuattroCalum
    1,964
    706
    Hope you find out what the problem is
    VAG-Slag likes this.
  11. mojocvh
    mojocvh Member
    185
    17
    Ha, I've got EXACTLY the same going on too with the solenoid chattering like crazy what controls/engages the solenoid electrically?
    kellsy79 likes this.
  12. Avatar
  13. kellsy79
    kellsy79 New Member
    Did anyone sort this problem as I'm having it now lol
    Sent from my SM-G930F using Tapatalk
  14. mojocvh
    mojocvh Member
    185
    17
    058905291K vacume check valve. beside airbox. replaced it and issue seems resolved for the time now. Funny thing is it seemed solid when cold but who knows when hot....
