  2. Dismiss Notice
2.5tdi Misfire
honestpete1964 Feb 27, 2020
  1. honestpete1964
    honestpete1964 New Member
    My Audi A4 b6 2.5tdi sport has developed a misfire and it's gone into LIMP HOME MODE along with the engine management light on, I put the car I into a garage & picked the car up 6 days ago. Yesterday it's gone back to how it was when it was in the garage, I've been back to the garage 3 times & each time I've been fobbed off.
    The car is FWD Manuel, has anybody had a similar problem ???.
    Thank you
  2. Avatar
    snack-media
    Advertisement
  3. pauldazzle
    pauldazzle Well-Known Member
    1,326
    116
    You need to get it read for fault codes, & go from there.
  4. stevey83
    stevey83 Active Member
    219
    27
    Diesels cant misfire, more than likely a knackered injector.
    What are the symptoms
    You would need VCDS to log each injector and see which one is different, or another method is to unplug them one by one and see which one is off. The faulty one wont make a difference, the good ones unplugged will make it worse.
    You could also try unplugging the MAF sensor and see if it runs any better.
  5. honestpete1964
    Thank you for that, tomorrow I shall get the car scanned to ascertain the problem.
  6. honestpete1964
    Thank you for the suggestions, I shall try that before I get the car scanned..
