2.0 TFSi Port Injection
15Degrees Sep 23, 2015
  1. 15Degrees
    15Degrees Active Member
    298
    176
    43
    Hi Guys
    Has anyone changed over a 2.0 TFSi to port injection? I know you can get the manifold but was more interested in the pistons and CR etc. To my mind you need the following items to do this
    1. Inlet manifold like IEs
    2. Set of injectors
    3. Ally fuel rail
    4. Fuel pumps feeding rail, swirl pot etc
    5. Manual fuel reg boost controlled
    5. ECU like MOTEC or Syvecs
    6. Custom engine loom to connect it all up
    7. Block up the injector holes in the head
    8. Pistons? Now I know the current pistons are optimized for the GDI and also the high CR. So I guess you would need the same CR piston but with a crown better suited to port injection as opposed to GDI
    Anyone done this?
    Mark.
  2. Avatar
    Google AdSense Advertisement
  3. 15Degrees
    298
    176
    43
    I guess No one has done it then :( Bummer..
  4. QuattroCalum
    QuattroCalum Well-Known Member Saloon saloon Audi A4 Black Edition Manual
    1,981
    710
    It doesn't mean to say it can't be done but as it's likely a first, you'd have to find all the problems and solutions by yourself. I guess you're trying to a oid the carbon build up on the inlet valves? A catch can on the crankcase ventilation system can avoid most of that.
  5. 15Degrees
    298
    176
    43
    Strewth a 2 year thread resurrection :)
  6. QuattroCalum
    1,981
    710
    Never noticed the post date, oops, I guess he just gave up then. Technically it's a step backwards anyway, better addressing the pcv system.
  7. 15Degrees
    298
    176
    43
    He is me and I never give up :) I actually went CDLA and finally got a decent ECU for racing, all problems solved nirvana awaits me..
  8. QuattroCalum
    1,981
    710
    CDLA? You got me there, care to explain?
  9. 15Degrees
    298
    176
    43
    I went to a CDLA Supa copa engine code and binned off the old engine totally.
  10. 15Degrees
    298
    176
    43
  11. QuattroCalum
    1,981
    710
