Hi guys
Trying to see if I ave a timing issue.
Here are my readings in VCDS:
Fuel consumption looks good at 0.60l/h for the exhaust cam.
HOWEVER - I DO NOT HAVE A TORSION VALUE IN MEASURING GROUP 004!!!
As you can see, it normally appears at the end on Group 04 in the fourth box. But it says there instead IDLE STABILIZATION, but it also says that for box three as well!!!
It says 0.0 degree's there in box four, BUT I've never seen any deviation from 0.0 AT ALL. So concerned it's not working (box four).
In box three I have 7.1 degree's KW, which would be running on the high side and require adjsutment on the inlet cam.
This is the latest version of VCDS updated last week!!! Fully licensed properly (i.e. I bought it).
I Googled and found a couple of reports of people also not having the TORSION box, but they seemed to be getting a reading in box 4 (assuming VCDS just mislabelled it).
What can I do that would force a deviation in the torsion value so I can check if the box four is working? I tried revving and nothing changed, hance me thinking it's likely not working!!!
Any help much appreciated.
