2.0 TDI cylinder heads
Beenie Oct 5, 2019
  1. Beenie
    Beenie Member
    71
    Afternoon all,
    I'm wondering if anyone can shed some light of the issue for me.
    I believe I may have a cracked head on my bkd A3, although it could be just a head gasket failure, I won't know until I strip it down. So, I plan to buy another head just incase, worst case scenario, while it's stripped I can replace the head there and then.
    But my issues comes from sourcing a replacement head. I'm tight, plus I'm saving for a house so it makes more sense to spend a little than a lot, anyway...... typing in "bkd cylinder head" into eBay brings up some questionable results. Other engine codes are mentioned as compatible but when internet searching for compatibility I can't find much.
    Jeez I waffle, ok simple question, Are BKD heads the same as AZV, BLD, BKP, BMN, etc etc?
    Is the prefix "A, B or C" at the end of the part number the same on all heads? Obviously with the bkd you want the C prefix as it's less likely (although not impossible) to crack, so with a BMN head is it the same deal?
    If anyone could help I greatly appreciate it.
  2. Avatar
    snack-media
    Advertisement
  3. bobby singh
    bobby singh BSR Gold Supporter VCDS Map User TDi Audi A4 quattro
    877
    547
    93
    Buy a AMC head if you really want to fix this problem. Buy a VW head (even C version) is a waste of time, they all crack over time.
    Have a look on German ebay you can get a head with valves for around £650 iirc
