  2. Dismiss Notice
2.0 TDI BMN - red oil light
wingz4life2788 Feb 14, 2020
  1. wingz4life2788
    wingz4life2788 New Member
    Bought a 2006 (registration) or 2007 (VIN) 2.0 TDI GT BMN engine about 6 months ago.
    Took it in for the red oil light flashing after I put in a new oil pressure sensor. Light still stayed on.
    Red oil lamp / light - engine oil pressure too low - stop engine and check oil level
    I brought it to a VW Audi specialist and the mechanic changed out the oil pump, oil and filter After the first test drive (30 mins) oil light did not come on. Took it for a second test drive and light came back. He then changed oil pressure sensor changed to OEM and changed crankshaft sensor.
    Light is still on. He did a pressure check and pressure came back at correct readings. He tested witing and thinks it's a dash fault?
    Any thoughts?
    Sent from my SM-N960U using Tapatalk
  2. Avatar
    snack-media
    Advertisement
  3. MPH
    MPH Active Member Audi A3 Manual
    198
    61
    Did you get the oil strainer changed?
  4. Eren S3
    Eren S3 Pretending to know what I'm doing. Team Dolphin Grey Silver Supporter Audi S3 Manual
    154
    61
    Could it be the oil level sensor? I don't suppose they let you know of any error codes that came up on a scan did they? Or do you have access to VCDS to get a scan yourself?
  5. wingz4life2788
    I believe he said he cleaned out the strainer with the pump, but not entirely sure as I did not do it myself. I'll call on monday to ask. My neighbor might have a scanner I can borrow.
    Do you know if there is more then one oil pressure sensor on this model? I'm thinking the MAP / boost pressure sensor could be throwing the signal just dont know how to check it without replacing it.
  6. SootySport
    SootySport Well-Known Member Team Silver
    4,046
    1,079
    There is also an oil quality sensor screwed to the bottom of the sump.
    I think you need to go to a recommended VAG specialist as they would know how to interpret any fault codes correctly, not just change out parts randomly.
