I have found i'm only getting 38mpg which is much less than the 1.9tdi A4 I used to have. It's had a new fuel filter and service, tyres pressures are fine, no fault codes, 18 inch wheels, temperature guage sits at 90 degrees. 165k on the clock. Timing belt was done recently and the timing was set back to zero (was retarded a couple of degrees) Any ideas what could cause this excessive fuel consumption? I've been told it could be something to do with the throttle?
