2.0 TDi 170 PD - What Oil?
Gazwould
505.01 not optimal but way better than 1997 505.00 :frown:
10W40 505.00
5W40 505.01
5W30 507.00
Pie-eyedpiper
Terrifying.
I might as well be using cod liver oil in my car for all the protection I get then.
However did VW get away with supplying a shockingly inadequate oil.
jarnold231
I've read through - but am a bit confused.
I've been putting 5w30 Castrol/Millers in my 1.9 every 5000-6000 miles. I'm assuming the car will be happy with this level of love?
Sent from my ONEPLUS A6013 using Tapatalk
Gazwould
Yes it's a higher level of love .
Starting to wonder why people don't have Asda plastered on car's in favour of Castrol, Millers and the like...
..go for branded stuff as I'm a snob :icon thumright: can't tell me supermarket oil, fuel or whatever is fine as it meets "standards" still not using it, each to their own..
Guess you've not heard of
then ?
Pie-eyedpiper
Its not a PD either I would think.
DieselJake
Well-Known Member
I just wanna know what oil I should be using
Anything 505.01 or 507 will be fine :icon thumright:
As a general rule of thumb most 5w40's and 5w30's meet this but just check the back of the container or read online first, personally prefer the former which ironically by definition can not be 507 so this whole it's got to be 507 thing which one person spams in every thread is totally flawed.
Gazwould
Why flawed if I can back it up from multiple sources and that includes information signed off by VW themselves who's oil spec it is ?
Spam , you are an entertainer DJ .
Jamsmoo
Be interesting to see what oil the vag specialist uses Monday with my oil pump work
DieselJake
Well-Known Member
Either is fine, regular changes are key.
If you don't plan on changing oil often, don't conduct much spirited driving and don't mind thicker oil 5w30 is fine. Probably find more garages use 5w30 as it's more universal but more enthusiasts want the lowest first number and highest second of which 5w40 is what is suggested by the manufacturer.
Gazwould
A true enthusiast would use the oil with the best oil performance peramiters inc anti wear .
If you want higher anti wear and you have a dpf then Fuchs do a unique C3 racing oil called Fuch Titan Race Pro C3 .
Pie-eyedpiper
I thought 1.9tdi BKE was a PD?
I stand corrected.
I thought the 1.9s were the older more reliable engines. I used to have one in a SEAT Toledo, it went like poo off a shovel.
jarnold231
I stand corrected.
This is confusing the **** out of me. I also thought the PD engines were the reliable ones? I now have the fear.
Pie-eyedpiper
I think the 1.9 PDs without the oil pump balance shaft are, better than the 2.0s anyway.
But not as reliable as the old 1.9s, a bit agricultural but live for ever.
ialexhaji
Go to TPS and get the Quantum oil that they will use in the Dealership.
I've been advised by TPS (and others) to use 5w40 once engine is over 100k on the 2.0 TDI
tr7
The question really is, who waits to 20,000 miles to change their oil?
I changed mine there recently, 4,611 miles. 18 months, 556days to be precise between services, very little miles was sick of the chime/light on the dash so did it anyway
Anyone else?
tr7
Why use Long Life oil and change it every 2 - 3k miles?
a) its not about long life, it's the spec/grade properties
b) because he's buying it for sub £1.50 per litre
c) changing oil is one of the best, most cost effective maintenance items you can
No brainer if buy it that cheap (and the oil is what it says it is)
I did 4,500 miles there in 18 months and changed my oil. Was £30ish quid.
I'd do it all the time if it was even less
Gazwould
This LL oil to go longer has to be stronger in the first place , of higher quality , higher oil film strength determined by oil basestock groups and additive package concentration .
Pie-eyedpiper
Great stuff.
Where does it say on the 3 cans in his photos that it's 507.00 long Life oil though.
Just says 5w30 fully synth to me, and for petrol and diesel engines.
So much for using dedicated PD oil.
tr7
You're right. It doesn't
But given how ****** anal he goes on about it I simply presumed it was
