Cruise control part number
johnnevett
Oldham
Hi
does anyone know the correct part number for the cruise control stalk unit for an 08 audi a4. Reg yf08 vrm
ive seen this one 8K0953502BD but have been told Option codes; BD adds 9Q7 & 9Q8, for the Fuel computer which is not on your A4 but I do have the fuel computer. Is this right. Cheers
Seems like BD would be ok for the saloon, with fuel computer, and you would need BK for the avant.
Note that the switches are a single block, you cannot easily mix and match modules from your old set and the new set.
(Echoes of lesson learnt the hard way...)
I fitted BD to my 08 Saloon with 9Q4...it works fine but there is an additional code change in VCDS required in addition to programming the cruise control in.
If you Adaptive Cruise or Lane Departure then you need a different part number. As above Avant is different as well.
If you wanted main beam to stay on the stalk would lock when pushed away from you. The BD stalk however doesn't and springs back. A quick change on the Central Electric module will sort this though.
