s-line style
quick question just bought some xenon bulbs off ebay (where a get most stuff lol) which are h7s will these fit my car a 54 plate a4? thanks
When did the cheapest become the best...? I've tried lots of bulbs, the only ones with any real improvements are an HID kit. I've recently done my mains and it's one of the best mod's I've ever done.
The easiest way to change the bulbs is to drop the lights out. Undo the two Torx screws on the top, and SLACKEN only the two bottom Torx bolts, the whole unit will then slide out and you can unplug it. Takes a couple of minutes only per side.
cheers people and yeah I just want the ice blue look it says there xenons I thought theyre meant to be brighter? not bothered if theyre not coz I have good eyesight in the dark anyway lol I just prefer the ice blue look over the yellowish standard lights
Got all of my bulbs at front end in Ice White from T8ups on here (emtuning on net) and they do give a nice white lightView attachment 16977
Just started a bit of research into (the mine field) of up rated bulbs for my B6 avant, not very impressed with the dipped beam so far.Not so fussed about white or yellow light but the projection down the road seems a little poor. Osram rally's or a set from T8ups?CheersMarkI recently changed my Osram Nightbreaker Plus bulbs (after one blew) for 65w Osram Rally bulbs. They are not road legal as they are over 55w but they fine from outside and certainly not dazzling like HID conversions. They produce a nice crisp white light (very similar to xenon lights when close to walls etc) and are noticably better than the Nightbreakers. Also from what I've read they shouldn't cause any issues with the wiring as they are only 10w greater than the 55w bulbs. They may not be legal but I found the lights quite poor on my B6 and these are much better without appearing different to other road users. Being halogen the beam pattern is also spot on for normal lenses.
