Just had this fault come up , abs light has been coming on now and again, well after braking slowly coming to a stop it felt like the diff was locking up, and i get thisany ideas ?cheersa4 3.0 v6 quattro 02
No mate, had a knock on the front a few months ago, dealer had to replace abs module as light wouldnt go off, few months down the line im getting this
May just swap it out , seen them on ebay for about £30
Is it a pig of a job, or fairly simple
Looking at the manual, it's not that straight forward. Different procedures depending whether you have ESP or not as they're two different units. Also, a recode with VCDS is required for the ESP version.
I'd suggest checking the connector on it for security of attachment and contamination if it's only been replaced recently. It's just below the coolant expansion tank in the engine bay.
