A3 8V Air vents retrofit
takes some time Yes! you have 2 options, cut the major part of the dashboard or trim down the 8V air vents, if you want the air to flow correct you need to cut the 8P vents and cut off the back part of them, i can see if i have some pictures of the procedure :)
Reactions: galanot
This was my solution, pay attention at the small edges i left over and also the "point track" (or what you say in English), from the 8P vents.
At the top of the 8V vents, the "protection" plastic is removed from the "rotation axle" and then everything else is cut off.. Nothing is removed from the bottom of the 8V vents!
The only thing remaining is to remove a small amount of dashboard, i take a picture in my car tomorrow! you need to go down 2-3 mm all around and 10mm deep into the hole to make it possible to turn the airflow on and off. I can put 8P vents back without any missfitting or visual marks. In the bottom of the hole you need to clear the way for the vent gears in the bottom, cut off the edge.
12371042 10153294722247285 1045620672888509675 o
12371090 10153294722622285 3371247173764163227 o
12363058 10153294722687285 7999074009234952509 o
12371100 10153294720567285 913368009863914159 o
nice one @Pergan !!! really usefull info! i might fall into this mod too :p now we will have more and more 8V inside our cars haha.
Reactions: Pergan
20161109 173045
Hello people. Directly from Portugal just set up this afternoon.
I follow the tips and its great.
I also do the ashtray removal for more spaceo.
Reactions: Pergan and VAG_Club001
View attachment 98775 View attachment 98776 View attachment 98777 View attachment 98778
I sent you a message. How did you guys removed the plastic ring?
