DTM register / owners thread
olethalb
I'm not sure if this could be made sticky but would be nice to have a thread for the B7 DTM where owners could post a pic of their car, we could see how many of the '250' are on here and keep track of them and compare mods etc.
i'll start off
spec;
sprint blue - 55 plate
AP coilovers
19 x 8.5 et44 rotiform BLQ with 215/35 tyres
S4 345mm front drilled / grooved brakes
FK grill (for now)
carbon fibre mirrors
satin black headlight internals
clear corner mod
debadged rear with black rings
R44 DTM registration
pioneer satnav / dvd double din
digital boost gauge (psi)
leather arm rest
carbon gearknob
B6 cigar lighter mod
Bose
lighting pack
CDL engine
K04 hybrid (turbo dynamics)
S3 injectors
AutoTech HPFP
RS4 Fuel pressure valve
Custom 3" intake
3" cone filter
BSH PCV delete
42 Draft catch can
Custom PCV blanks
Custom FMIC with custom pipework
AEM WMI
Cold side DV relocation
D rev DV
APR Decat pipe
Milltek Cat back system 100mm tails
polybush snub mount
034 single mass fly
southbend stage 2 endurance clutch
RS4 fluid cover
TDI a/c cover
scuttle and battery cover
Reactions: tr7, Inertiauk, markmac89 and 5 others
I am one of the 250, but have robbed it and spirited it away to the emerald isle. :p
mine is also Sprint blue and was on a 55 plate.
No mods yet (work to start in march)
1 mod compleated (carbon wrap of rear silver strip ) not much but it is a start.
by the way, olethalb. your build thread is my new bible :applaus:
Reactions: tr7
Ok ill go next :)
Spec:
Phantom Black 55 plate
19 x 8.5 et 45 OEM Rotors wrapped in 255/35/19 Continental Contact sports
H&R springs
2012 RNS-E-PU
RS4 Mirrors
RS4 Rear arb
S4 door blades
RS4 pedals
RS4 front fog grill mod
Custom front OEM RS6 grill
Clear corner mod
Pressed aluminium plates
RS4 battery cover panels
RS4 fluid bottle cover panel
LED DRL
LED rear plate lights
Debadged rear with just a DTM badge
Planned Mods:
TTRS multifunction steering wheel
12mm rear and 10mm front spacers
Carbon fibre rear boot trim (bought just been too lazy to fit yet)
LED side lights
Carbonio filter
Red coil packs
LED rear lights
Reactions: tr7, Av4nt and MorkC68
Craichouse - thanks for posting, brings back memories of when i first got mine in standard trim
Rob - love the custom grill work, a fair few parts you've got that i want to get in the future
lovely cars, thanks for posting
just came across this on google, probably not completely accurate but interesting
Yup, Olethalb's DTM is awesome. I love the attention to detail and OEM looks!
Well, here's mine so far:
Genuine RS4 Front Grill (a right mission for DTM owners!)
Clear corner headlights
FK Highsport Coilovers (pretty hard ride!)
H&R Spacers - 10mm Front, 12mm Rear
REVO stage 1 remap (Noticeable performance gains, well worth it)
Plane, screwless numberplates
Build Thread Here
26
22
23
25
27
29
On the 'to do' list:
Aluminium Trunk Strip Removal (Thanks Craichouse)
Full service
Apple Airport Express install (Wired off 12v)
... I'm tempted to sell up in a years time to buy something faster, I'd love a Wide Body K04 S4!
Thanks for posting, good work on the RS4 grill, looks much better :)
Here is mine
Mods
· RS4 rear ARB
· Genuine S4 Calliper carriers and larger brake discs
· K04 turbo, S3 injectors, HPFP
· 200 cell Sports Cat
· Milltek full exhaust
· Audi B8 MFSW
· 2009 TTS Gear Knob
· S4 silver mirrors
· ITG air filter
Love it!
Where did you get the RS4 grille?
Reactions: tr7 and Gav:in
I got mine on eBay in the end, bought a genuine 'black optics' grill for £200 and sold the surround for £50. Theres a few replica grills out there but I don't think they look as good as a genuine grill.
Its a fiddly job to fit, pretty daunting when making the first cut in a expensive grill!
DTM_T4 question?
What H&R lowering springs did you use?
i was thinking about going for the 45mm ones.
H&R 45mm Lowering Suspension Springs A4 B7 Avant / Saloon 2.0T FSi Quattro 01/05> - £186.00 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspension and performance parts fo
or should i go for the 30mm ones?
i know because of the sports suspension there will not be as much as what they say.
After contacting DPM asking what the lowest drop I could go for without going to coilovers they suggested these 45mm springs:
tThese were the springs I went for and im chuffed to bits with them. Like you mentioned tho as the DTM version is 15mm lower than standard it will give a 30mm drop from standard DTM springs. I will say tho that after having them fitted for a couple of months now that they do drop a bit more from when you first fit them after a few hundred miles.
hope this helps
Rob
question for spider 74 and olethalb. With the S4 brakes, can you use the original callipers and just get the S4 carriers and disks or do you need to use S4 callipers, carriers and disks?
Just the carriers and discs mate, your calipers just bolt on. Very easy job to do. Big difference for little cash.
hope this helps
Rob
that is exactly what i wanted to hear. this thread is paying for itself already :yahoo:
guess what i am spending my work bonus on this month......?
Spider - thanks for taking time to post, i know you've been on track with yours - does RS4 ARB make that much difference?
Id say the RS4 ARB is a worth while job for the cost. Easy to do and about £100. Main thin it does is help correct the Audi Under steer. Makes the back end feel lighter and to me balances things out nicely. Its subtle but you will feel a difference, even changing lanes on the motorway it will feel planted. Its not a remap different but should be on everyone's list! :)
Part numbers as best i remember from my notes.
RS4 Rear ARB Kit including:
1 x RS4 Rear Sway Bar (Part #8E0511409AL)
2 x RS4 Rear Sway Bar Bushings (Part #8E0511327D)
2 x Bushing Brackets (Part #8E0511439)
4 x Bolts for Brackets (Part #N10127707)
2 x Bolts for ARB links (Part #N10528103)
Hi,
Thought I'd best reserve myself a space in this thread.. A4 DTM, Sprint blue, mostly standard. :whistle2:
Might get a few pics up, but you can get a fair idea of what it looks like from everyone else's :icon_thumright:
I might even have seen Olly's black DTM on the M40 the other day, or maybe in Tesco petrol about 8 months back.
Spider - thanks for the info and part numbers :)
Rich - get some pics up
yea, rich get some pics up....:whip:
by the way, olethalb, this is the best idea you have had since you bought your DTM. this thread is not even a page long and i have already learned a few things. :respekt:
Hey Olly, why are you adding that? If it's for AirPlay to the radio, or video to the RNS-E, are you aware of this product instead?
Kivic One
The Kivic One looks pretty good!
I have a X Carlink sat around, along with an old airport express. I fancied making something that could use Apples built in Airplay function to stream music from any iPhone, iPod etc to my OEM head unit. I'm going to make a small housing to hide everything in the glove box or draw under the front seats. Any way, theres much easier ways to stream music, I just fancied a little project.
If any ones interested, heres all the 'how to' guides I've found so far:
Stream music to your car with a USB powered Airport Express | After Hours
http://www.instructables.com/id/Converting-a-Broken-Airport-Express-PSU-with-an-US/
How to Repair a dead Airport Express so it runs on a 5 Volt Power Brick
| ||| | | weistudio 2006 || | ||| |
Wifi Airplay through the Stereo! - Honda Element Owners Club Forum
It probably wont work but will keep me entertained for a while!
a quick one lads,
how do you clean your alcantara on the steering wheel ?
i want to try and restore the bits on my wheel (i wont be replacing it for a while) because they have become all shiny :sadlike:
and before you say, it was the previous owner who did not take care of it :asskicking:
mine's worn too, holding out for a FBSW with round airbag :)
Flat Bottom Steering Wheel, s3 / rs4 / tt - that sort of thing :)
Does anyone know if there are any company's or individuals that could do the RS4 into the DTM grill conversion as this is the final mod I need to do to mine but I don't have the necessary skills, patient's or balls to do it myself.
a quick one lads,
I use the interior trim cleaning cloths on mine - yes, mine also looked worn but often it's actually just stuck down with grease and dirt and will spring back fresh if you give it a clean. Give it a rub with one of those wet interior cleaning cloths and check if the cloth is picking up dirt. Keep going until the cloth comes away clean and you're laughing.
Let me know!
Let me know!
Let me know!
Any particular brand bud? might get a couple more £ when i pop it up on ebay if it looks nicer :)
hello mate can u give me photos of the ride height on yor dtm can u give me the phone number for place u got them from aim running 19'
buy the way Spider74, that is a lovely shot
Nürburgring?
Yup its the famous carousel at the Ring :)
Car performed well on it for as far as i was willing to push it (tame compared to most nutters on there)
right, its pay day. i am off to start work on my DTM project.
Step 1. H&R 45 mm Lowering Suspension Springs and some spacers (12 mm rear and 10 mm front)
Step 2. refurb and paint of DTM alloys to gunmetal grey
Let me know!
did this today exactly like you said, using this:
Steering Wheel Cleaner - Armor All® Natural Finish Detailer Protectant
and it worked perfectly :thumbsup:
20 min job and it is like having a new steering wheel.
Nice work! I might even buy a few of those ones myself, despite saying I'm not brand loyal.
Today I followed Olly's tips on easy N75 valve removal and I can confirm I think I found the souce of my intermittant under-boost :think:
Happy days!
Afternoon chaps.. just stumbled on this thread fortunately. I am thinking about chopping in my A4 B7 Cabriolet (2.0 tdi - 2007) for a DTM. Seen one in silver which looks pretty nice, with Nav, and all the other standard bumph with about 64k on it for £9.7k. Do you think that sounds like a decent price and is there anything I should look out for on it?
