Just recieved vagcom cable from nigel today, plugged in and...oh hell
this lot...15 Faults Found:
16955 - Brake Switch (F)
P0571 - 35-10 - Implausible Signal - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 -
18057 - Powertrain Data Bus
P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - Intermittent
16687 - Cylinder 3
P0303 - 35-10 - Misfire Detected - Intermittent
16685 - Cylinder 1
P0301 - 35-10 - Misfire Detected - Intermittent
16688 - Cylinder 4
P0304 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
P0302 - 35-10 - Misfire Detected - Intermittent
16396 - Bank 1: Camshaft A (Intake)
P0012 - 35-10 - Advance Setpoint not Reached (Over-Retarded) - Intermittent
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
17545 - Fuel Trim: Bank 1 (Add)
P1137 - 35-10 - System too Rich - Intermittent
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-10 - Implausible Signal - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
17658 - Fuel Level too Low
P1250 - 35-00 -
Readiness: 0000 1000
thats just the engine faults...
Just had (3 weeks ago) new cambelt fitted + metal water pump, new v belt, new breather hoses, oil sump removed pick up cleaned out, new filter and oil level sensor.
New starter motor...and new brake caliper, discs and pads all rounds...recon abs system.
Any help much appreciated
