i recon the timing between cams is out. 16 rollers between gears and both squares on the cam in line with the arrows on the cam bearing caps. It's a pain as you can set it, but when the tensioner fills with oil it pulls it out of time.
Obviously this is assuming the main crank/cam timing is accurate.
