Some progress was made this evening.
I removed the VVT solenoid and took out the pin that controls the oil flow. The idea was to get the tensioner to work as a non VVT tensioner.
Started the car at a high rpm cold start, slight misfires but dint stall, the engine warmed up.
I have cleaned out the VVT oil passage and installed the pin again. I will try a cold start in the morning. It if turns out to misfire and stall, I plan to "hotwire" the VVT solenoid with direct power and see if that helps with things.
Maybe the VVT solenoid has had it and doesn't have enough juice to push the spring loaded pin.
to be continued............
