Some of you might know I am building a 2.0L 20V Big Turbo. I'm not going to do an in-depth build thread as I'm sure most of you know how these things go.
Parts list
Gaskets and bits needed to assembly an engine.
Timing kit and new water pump
Wiseco 83mm pistons and IE rifle drilled con rods
Cat cams and pulley - I removed the stupid locking spring pin and pressed in a solid stainless pin.
Assembled 2.0L FSI crackshaft with oversized pistons.
Large port AEB head with supertech valve train
Engine assembled
The clutch kit with lightweight flywheel
New oil pump
Lightweight pulleys, exhaust wrap and some silicone bits for the TIP
80mm hemi throttle body
K&N air filter
Bosch 044, IE fuel rail and 034 motorsports FPR housing
Fuel pressure gauge - saw this on ebay and liked the look - it will match my colour theme
Home made stainless steel surge tank
Wastegate and 830cc injectors
90mm maf housing - B5 RS4 has the same size housing as a B7 S4
FMIC with 3" inlet/outlet
Home made inlet manifold, fitted the fuel return line to the manifold.
Parts list
Engine assembled
New oil pump
K&N air filter
