170 TDI cambelt price!!!
red or dead
Hi all,
I know the answer to my question will be somewhere on the forum but the search won't work for me properly.
Roughly what price am i looking at for a cambelt change on my '07 a3 2.0 TDI 170?
Audi have just given me a price of £681.96, which I'm thinking is a bit on the steep side!
Dannykn9
"Cruise My Ride"
Audi Chingford charged me for my 2006 "56" 170, £525 and that included water pump and alternator belt. this was only about 2 months ago.
audicruiser
Audi Heaven
Had mine done in at Audi in February, Cambelt, water pump and tensioner £469... You have to haggle!
red or dead
Hmmm...thanks, so really they're just trying to have my pants down, maybe because they just put £600 worth of parts on for free, it's just been in for the injector recall.
All together they want £1122 for new front discs and pads and rear pads plus the cam belt change. I'll probably get the brakes done elsewhere but would like to keep the cam belt with Audi.
Dannykn9
"Cruise My Ride"
You could go to an Audi Indy who use only genuine parts as they will still be much cheaper.
markm3006
Is the 170 tdi cambelt change a milage thing or age related ? :slapped:
Dannykn9
"Cruise My Ride"
Supposedly 70,000 or 5 years. So I was told by the dealer!
MTRL
Split Grill!
I paid £325 to get cambelt and waterpump changed. HOWEVER, my car is back with them now because the engine mount/bolts failed and the engine fell through the bottom of the car.
They are looking at it tomorrow to decide weather it is their fault or not.
No doubt they will try to say it isn't and will try and charge me for picking up the car and inspecting it.
Very stressed out.
I was told 50K or every 5 years
red or dead
I really wanted to keep it Audi as I bought the car Audi Approved and have kept all work at Audi over the last 2 years but this is just a bit too much.
I've already rung a couple of specialists and they are getting back to me tomorrow.
red or dead
Yep, its something like that. :laugh:
In fact, thinking about it, it is 5 years cos my car is a 2006 and I had it done in 2011.
Although I could've been a year late!? :think:
Yeah it's 5 years or 65k, or so they said and told me it needed "urgent attention" even though the car still has 3-4 months until it's 5 years old!
Ads
ASN Veteran
Very stressed out.
Same thing happened to me... minus the engine falling out. Its pretty common that mounts fail when being disturbed during a cambelt change. Although usually they'll just knock a bit, as mine did.
Audi replaced mine at the cost of just the parts, but if yours were so bad that your engine fell out then I think you've got a good question to ask them about why they didn't notice something when they re-secured your engine after doing the cambelt.
Good luck.
red or dead
Very stressed out.
Was this at a main dealer? Now this is making me want to get it done at Audi in case something like this happens and the "specialists" turn out to be cowboys!
Dannykn9
"Cruise My Ride"
In all fairness mate, just because they are main dealers, it does not make them experts as you will find a lot of dealers of whatever brand have a lot of apprentices.
A lot of the time, indies are known to be better with more experience.
MTRL
Split Grill!
Good luck.
Cheers, I get the feeling im going to have to fight this the whole way. They wern't supprised when I rang up and told them what happened. Must have happened a few times. Shouldn't happen without someone messing with the mount. They were the only ones to touch it when changing the cambelt.
We will see what tomorrow brings. Hope I dont have to tow it back again!
MTRL
Split Grill!
No it was a "specialist", dont want to slag them off just yet. Will reserve judgement untill I have seen how they behave tomorrow.
RapidAssistant
I thought Audi charged £399 fixed for a cambelt change?? I went to my local specialist who did it for £310 on my old B7 A4, but that also included the water pump which I am not sure you get at the Audi dealer - I was strongly recommended to change the water pump on the 2.0TDI engine based on past experiences.
daddycool
£425 for cambelt, water pump & dsg oil change. Wouldn't bother with main stealer unless your cars still in warranty or you've got more money than sense!
murran
is it the bolts that hold the side mounting to the block that have snapped? if so then theyve eith massively over tightened them or left one loose (the lower one).
or have the two m12 18mm headed ones come out of the side bracket?
red or dead
Well I got a quote from a friend of a friend today, he say's he'll do;
cam belt
water pump
fan belt
coolant
rear pads
service, including oil and filter changes
full diagnostic
All for the grand total of £465
Seems a bit too cheap TBH but I'm not complaining, Audi wanted £1122 for cam belt and brakes only!
Beans
The labour for a cambelt on that car should be 2.3hours.
Beans
Audi quoted 4.10 hours labour for the cambelt at £115 per hour!
That 2.3hrs is just for the cambelt and tensioner, that figure is from Autodata. Unless it includes something else, that is a rip off.
MTRL
Split Grill!
The report back from the garage said that two of the bolts had sheared in half. I think they were the bolts that hold the side mount to the block. I think you are right, one may have been left loose and had come out over the next month or so and sheared the remaining bolt.
The garage fixed everything under parts warranty and my car was waiting for me when I got home yesterday all fixed.
They have put in a whole new mount and repaired everything that had ripped out of place or that had been squashed/bent.
Honestlly I thought I would have a massive ballache on my hands, that they woud deny they did anything wrong, bill me for recovery and inspection and leave me up **** creek.
But they were really impressive, after everything I would go back there.
Lesson for all I hope, check the bolts after a cambelt change.
They are stretch bolts for single use only. Make sure they are re-newed.
MTRL
Split Grill!
Was it a main dealer or an Indy?
Independant, VAG specialist.
Looking on the net after it happened I found quite a few threads (not just audi) where this had happened to other people. Could happen with the dealers too.
All down to human error I suppose. Mechanics dont have Audi part numbers stamped on them so you just have to trust they wont make a mistake.
Djwoody
I have just had my 2008 170 TDI cambelt changed this week, along with tensioners and water pump.
Also had an Oil change as well when it was in the garage.
It was done by a local mechanic that has been a family friend for years and he charged me £350 which I thought was really good.
Think the cambelt kit itself is about £140 for the CR170 engine.
Chris
max69vk
Active Member
It's my birthday
Everyone ready for a laugh? This is based on the 'fixed pricing' apparently....
:wtf:
BlueSpark
6th Gear
LOL that cant be right..they are definitely trying to pull one over on you! i think i paid somewhere in the region of £469 for mine last year which included water pump change.
max69vk
Active Member
It's my birthday
Just mailed them this....
Hi *******,
Just wanted to check the pricing on the cambelt quote I had from you earlier today. After looking at this:- Affordable servicing < Servicing with Audi < Owners area < Audi UK it shows the cambelt service price at only £429 inclusive of parts, labour & oils etc, & Audi UK have confirmed that my car falls into the correct category for this work to be done at this price. Having spoken to a couple of other dealers in the area they have quoted me £480-£500 to have this work done including the water pump, against the quote of £835 received earlier.
I’m sure there has only been a simple mistake but could you please have a look into your quote (1266089) & get back to me as if the car is going to be in for a few days, it is probably worth doing at the same time.
The reply...
Hi Max,
£609inc VAT is our deal price on cambelt & waterpump.
I couldn't be ***** to argue so i just told them I'm going elsewhere!
