merdzo
Hello everyone... I just want to made some changes to friends car and i fu*ked up...
i was trying to turn off belt buzzer but i put wrong code and i think i made some issue with the instruments controller...
here is the OLD (good) report of auto scan
Sunday,03,November,2019,20:24:48:59220
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0
Data version: 20190930 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8PX4A179745 License Plate:
Mileage: 268490km-166831mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 7D
VIN: WAUZZZ8PX4A179745 Mileage: 268490km-166831miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Not registered 0011
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 G HW: 028 101 136 4
Component: R4 2,0L EDC 0000SG 5705
Revision: 12345678 Serial number: AUX7Z0D4FNB0AD
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 2733B760FA36AC53E2-8072
2 Faults Found:
19559 - Motor for Intake Manifold Flap (V157)
P3103 - 000 - Malfunction
Freeze Frame:
RPM: 819 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 11000000
Torque: 172.0 Nm
Torque: 0.0 Nm
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 819 /min
Torque: 62.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11000111
Temperature: 14.4°C
Bin. Bits: 10110000
Readiness: 1 1 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0103
Coding: 0023174
Shop #: WSC 06435 000 00000
VCID: 3A4E695FA6D73EE87A-806E
No fault code found.
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
Component: KlimavollautomatH12 0150
Revision: 018098 Serial number: 8P0820043E
Shop #: WSC 00000 000 00000
VCID: 2E3A817B9613761CDA-807A
1 Fault Found:
00483 - Control Module for Auxiliary Air Heater
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 268435 km
Time Indication: 0
Date: 2019.11.02
Time: 07:21:34
Freeze Frame:
ON
Address 09: Cent. Elect. Labels:. 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000788512
Coding: 0188CF0082141000000000000000000000
VCID: 3B4F6F5CAAD224E742-806E
Subsystem 1 - Part No: 8P1 955 119 C Labels: 1TX-955-119.CLB
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
8 Faults Found:
01320 - Control Module for Climatronic (J255)
004 - No Signal/Communication - Intermittent
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00466 - Control Module for Steering Column Electronics (J527)
01332 - Door Control Module; Passenger Side (J387)
01331 - Door Control Module; Driver Side (J386)
01330 - Central Control Module for Central Convenience (J393)
00526 - Brake Light Switch (F)
008 - Implausible Signal - Intermittent
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0010602
VCID: 43577F344ABAF4AF82-8016
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
Component: Lenksäulenmodul 012 0030
Coding: 0000012
VCID: 3038857D9E197A122A-8064
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
Component: KOMBIINSTR. VDO H25 0150
Revision: D10 Serial number: 2244DD10060507
Coding: 0004003
Shop #: WSC 11111 111 11111
VCID: 3545934EB2F018CD12-8060
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 250010442204D1
Coding: 3D0F0B02070100
Shop #: WSC 78603 150 98551
VCID: 2830B565FE31AA6AEA-807C
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 1
Fault Frequency: 254
Reset counter: 4
Mileage: 262855 km
Time Indication: 0
Date: 2019.07.04
Time: 15:14:15
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D10 Serial number: AUX7Z0D4FNB0AD
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN1.lbl
Part No: 8P0 959 801 A
Component: Tuersteuerger. H10 0010
Coding: 0000016
VCID: 39416B5AA2CC30D172-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 B
Component: KSG H02 0040
Coding: 008800186D288505484A016000
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH25 0160
Revision: 00003 Serial number: 10000001122785
VCID: 707805BD9ED9FA522A-8024
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN1.lbl
Part No: 8P0 959 802 A
Coding: 0000016
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 HW: 8P0 035 186
Component: concert II EU H53 0060
Revision: 08S Serial number: AUZ2Z3D2151472
Coding: 0001001
VCID: 6F7B07B89ADEFC5B22-803A
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 7
Reset counter: 34
Time Indication: 15
Freeze Frame:
Bin. Bits: 10
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 34
Time Indication: 15
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
Component: PTC-Element 0404
Revision: 00700000 Serial number:
VCID: 2C3C8D71EE0D420ECA-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
014 - Defective
End-------------------------(Elapsed Time: 01:44)--------------------------
Address 01: DTCs cleared
Address 08: DTCs cleared
Address 09: DTCs cleared
Address 19: DTCs cleared
Address 56: DTCs cleared
Address 7D: DTCs cleared
09-Cent. Elect. -- Status: OK 0000
56-Radio -- Status: Not registered 0001
Coding: 0000072
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Readiness: 0 0 1 1 1
Coding: 0023174
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 268435 km
Time Indication: 0
Date: 2019.11.02
Time: 07:21:34
Freeze Frame:
ON
Coding: 16711696
Shop #: WSC 00000
Coding: 0010602
Coding: 0000012
Coding: 0004003
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 4
Mileage: 268492 km
Time Indication: 0
Date: 2019.11.03
Time: 20:33:22
Coding: 0000016
Coding: 0000016
Coding: 0001001
1 Fault Found:
014 - Defective
End-------------------------(Elapsed Time: 01:40)--------------------------
Address 09,8P0 907 279 A,recoded (Long Coding),from,0188CF0082141000000000000000000000,to,0188CF0282141000000000000000000000,(00000/000/00000),
Address 17,8P0 920 930 F,channel 4,adapted from,1,to,2,
i was changing the values to CODING (no long coding helper) and after i change the code - fuel goes down.. i push TEST and IT PASS !.... after that on next scaning MODULE IS NOT WORKING PROPERLY!
this is what NEW scan looks like..
Sunday,03,November,2019,21:52:22:59220
www.Ross-Tech.com
Mileage: Repair Order: sdfsdf
17-Instruments -- Status: Malfunction 0010
Coding: 0000072
VCID: 27E2E0D10967F38251-8072
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Readiness: 1 1 1 1 1
Coding: 0023174
VCID: 3AF1DA88F5384D1F29-806E
VCID: 2EEDF2A4254485B389-807A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 268492 km
Time Indication: 0
Date: 2019.11.03
Time: 21:42:37
Freeze Frame:
ON
Coding: 0188CF0282141000000000000000000000
Shop #: WSC 12345 123 12345
VCID: 3BFED88DF9034B1631-806E
Coding: 16711696
Shop #: WSC 12345
Coding: 0010602
VCID: 4306A86599EB1BDE71-8016
Coding: 0000012
VCID: 30EBF6AE2D4A894199-8064
Address 17: Instruments Labels: None
VCID: 55148C5F0181EF5CC1-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
VCID: 28E3E6D60D62F99959-807C
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 4
Mileage: 268492 km
Time Indication: 0
Date: 2019.11.03
Time: 20:33:22
Address 25: Immobilizer Labels: None
No Faults Found
Coding: 0000016
VCID: 39F0C48BF13D470021-806C
VCID: 35F4CCBFC121AF7CC1-8060
Coding: 188800186D288505484A016000
VCID: 702B76EE2D0A098199-8024
Coding: 0000016
Coding: 0001001
VCID: 6F2A70E9290F038A91-803A
VCID: 2CEFFEA23D7E91BDB9-8078
1 Fault Found:
014 - Defective
End-------------------------(Elapsed Time: 03:25)--------------------------
i can not even see the coding vag number... NOTHING !!!!
im wondering - is it possible to upload/put a lbl file from other audi a3 or i need help - if someone have this type od odometer / instruments to upload lbl file... i must fix this and its goes me crazy for a week and more !!!
p.s does VCDS save auto files (lbl) so i can find in my computer that old working file to restore the instrument controller ???
www.Ross-Tech.com
Coding: 0000072
2 Faults Found:
Freeze Frame:
RPM: 819 /min
Torque: 40.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.52 V
Bin. Bits: 11000000
Torque: 172.0 Nm
Torque: 0.0 Nm
Freeze Frame:
RPM: 819 /min
Torque: 62.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 11000111
Temperature: 14.4°C
Bin. Bits: 10110000
Coding: 0023174
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 268435 km
Time Indication: 0
Date: 2019.11.02
Time: 07:21:34
Freeze Frame:
ON
Coding: 16711696
Shop #: WSC 00000
8 Faults Found:
Coding: 0010602
Coding: 0000012
Coding: 0004003
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Reset counter: 4
Mileage: 262855 km
Time Indication: 0
Date: 2019.07.04
Time: 15:14:15
Coding: 0000016
Coding: 0000016
Coding: 0001001
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 34
Time Indication: 15
Freeze Frame:
Bin. Bits: 10
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 34
Time Indication: 15
1 Fault Found:
014 - Defective
Coding: 0000072
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Coding: 0023174
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 268435 km
Time Indication: 0
Date: 2019.11.02
Time: 07:21:34
Freeze Frame:
ON
Coding: 16711696
Shop #: WSC 00000
Coding: 0010602
Coding: 0000012
Coding: 0004003
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 4
Mileage: 268492 km
Time Indication: 0
Date: 2019.11.03
Time: 20:33:22
Coding: 0000016
Coding: 0000016
Coding: 0001001
1 Fault Found:
014 - Defective
www.Ross-Tech.com
Coding: 0000072
1 Fault Found:
Freeze Frame:
RPM: 0 /min
Torque: 88.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11000100
Torque: 0.0 Nm
Torque: 354.0 Nm
Coding: 0023174
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 4
Mileage: 268492 km
Time Indication: 0
Date: 2019.11.03
Time: 21:42:37
Freeze Frame:
ON
Coding: 16711696
Shop #: WSC 12345
Coding: 0010602
Coding: 0000012
No Faults Found
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 4
Mileage: 268492 km
Time Indication: 0
Date: 2019.11.03
Time: 20:33:22
No Faults Found
Coding: 0000016
Coding: 0000016
Coding: 0001001
1 Fault Found:
014 - Defective
