A3 2.0 tdi FMIC...
ElliottB
Audi A3
Hull
Anyone got a 2.0 TDI with a fmic....if so what intercooler do you use and have you got pics?
No point doing it as the standard I/C can handle more than you'll be able to get out of the engine, try improving the ducting to the I/C from the front of the car as this is the biggest issue with it in standard form.
Std IC is front mounted,
You wont need a bigger IC until you fit BIGGER turbo , unless of course std one is damaged and you are thinking of future power mods;)
what would you suggest to improve it? induction kit?
S3 will be going on mine soon, I have a hybrid on mine.
do you need to put a S3 one in? as they say the standard one is good for 300BHP?
has anyone used a charge cooler? i used to have one on a petrol turbo car (not an audi) and the difference fitting that alone over a standard intercooler was massive.
sorry if youre not familliar with what they are, i should have explained that they are basically a water cooled intercooler rather than air cooled.
The S3 I/C will fit but it needs some modification to the hoses as the attachments aren't in exactly the same position as the TDI I/C. One definate improvement of the S3 I/C over the TDI I/C is that it is an all alloy construction rather than having plastic connectors, which invariably always leak a certain amount (the exception to this are the S3 I/C's from around 2010 onwards which also have plastic connectors).
The standard TDI I/C & intake are suprisingly very good (bar the plastic I/C connectors) & should be good for 250+ bhp. I'd suggest the extra ducting to the I/C purely for the improvement it can make during the summer (or supposedly hotter) months, but even this wont make an exceptional difference.
As I'm not planning on slapping a hybrid on just yet (my turbo was only replaced 500 miles ago by Audi) the one thing I have been toying with is adding ducting from the front of the car into the airbox, the idea being that diesel engines run very lean yet the more fuel you can get into the engine the more oomph you can get out of it. By forcing more air into the intake (idea being the faster you go the more air will be forced through the ducting at the front of the car) the engine will then add more diesel to balance the fueling ratio, & more fuel = more power. This mod wont make huge gains, possibly 3-5bhp at best, however for the price of a £5 piece of ducting it's probably one of the simplest & best £/bhp mods you can do.
If you are thinking of buying a new intercooler, I assume you have already removed the EGR and the silencers? These will have a far greater effect on the way the car drives. The EGR is fiddly, but removing the silencers and fitting with straight pipes is very easy/cheap and doesn't really make much difference to the exhaust sound.
Combine these with a custom map and you'll be flying along in no time.
Sorry to dig up an old thread but I'd like some clarity on this subject.
The car im now driving 2.0 TDI hybrid turbo has a FMIC fitted but not piped in. Apparently it made the car feel too laggy so he re-piped the standard IC back in.
What I would like to know is if anyone has logged their AITs with VCDS with a stock IC then with a FMIC?
The benefits of a FMIC are more then most people think an it doesn't just apply to a certain power level. The whole point of a FMIC is to cool the charge air from the turbo as much as possible before it reaches the AIT sensor and TB. I'm sure we'd all agree that you can feel how much more sharp our cars are on a freezing cold day compared to a hot one?!
The main issue with most standard ICs I that they suffer from heat soak! After a few spirited blasts the IC is hot from the charge air and struggles to recover so becomes fairly useless. A FMIC is smack bang out in the cold air and due to its larger surface area remains nice and cold which keeps the car feeling crisp.
Anyway, I'm sure you all know the blurb. Just wondered if there were any AIT logs from anyone and if you could let me know the dimension of your FMIC cores. I'm guessing the one I have maybe too large and that's what's causing the lag. I'll try to do some of my own AIT logging at the weekend.
Where is your current (in use) intercooler?
Earlier in the thread it is stated that the 2.0TDI has a front mounted intercooler as standard.... and I can confirm my IC is front mounted, and the car is not modified.
Ooooo, not sure! I assumed it would be side mounted like the 8L model. You know what they about assumptions!
So it is possible that the FMIC that has been fitted is now sittin infront of the OE one?! Not a good idea that! I'll have the bumper of this weekend and have a little look.
Can't imagine it to be honest, as theres already an IC, a rad and an aircon rad, so not much room lol.
Best to have a nosey and see whats going on.
Reactions: Westy
Can someone confirm that the following picture is indeed the engine layout of the 2.0 TDI A3:
Similar,
Mine is PDD170 and i know its a sheet photo but you can see oil cap, top left and there is a shroud over the dip stick.
Will get a better picture after work,
Westy, it looks like a CR engine, is that the one you are after?
Mine is a 140PD 2.0TDI, and looks slightly different to the above.
It looks roughly right for the location of the intercooler, just minor differences with the routing of the pipework tbh
Reactions: Westy
Ok so I got round to logging my intake temps last week and wanted to know what other people are seeing?
Outside temp - 7.5 degrees Celcius
Max Temp - 26.1 degrees.
Intercooler - Standard
Can those of you with full VCDS do a run and let me know what your results are please.
I'll do a log this afternoon/evening, got about an hours worth of driving this afternoon to do and then a trip out tonight with probably another hour behind the wheel.
I'll log the intake temps and outside temp and let you know what they average and peak at if that helps. (Also a BKD engine).
Reactions: Westy
Just got home from the office, had a quick look on way home and intake temp was 13 degrees and outside temp 10.5 in stop start traffic, motorway cruising saw 15degrees average and hard acceleration saw a very brief peak of 24 degrees, no matter how hard I pushed or for how long. Wasn't a particularly long drive though, maybe 12 miles.
I'm out again in a couple of hours so will compare temps then, as the outside temp will have dropped so I'll see if the intake temps drop accordingly.
Reactions: Westy
Hi mate, it's stock fmic, stock turbo with just a map, 180bhp.
Just got in from an evening out and was a good long run home. Outside temp 5, intake 10-12 on motorway/normal driving. Pushed it hard for a couple of miles to see how high I could get it and it maxed at 22, for a brief moment. Then just some normal fast road driving saw it average 16.
Hope this is of some help!
Reactions: Westy
I always thought that the rad and the cooler was one unit ??
Thanks smithy, that is good info. It looks like the stock FMIC is fine on a stage 1 car like everyone says. Be nice to see what figures some of the guys are getting with hybrids or BTs.
Any pics of people fmic fitted ?
Most people have just upgraded the stock FMIC with an S3 one which has Ali ends which apparently aids cooling which I why I want data ;)
There doesn't appear to be too many people running aftermarket FMIC that are just behind the bumper in the cool air. So you'll be hard pressed to find many pics Dan.
But the standard one is a massive unit so get rid of that one get a separate rad and cooler I'm quessing
I'm trying to figure out whether it's worth having an aftermarket one fitted out in from of the rad and AC. I'm sure it will be an I'm sure the 2.0 TDI be benefit from cooler AITs but so far both myself and smithy are getting 20 degrees above ambient. Now I don't know whether this is good or bad but I do know that if it's 30 degrees outside that an AIT of 50 degrees is quite hot.
Didn't really answer my question bud the whole unit is it complete as mine has a crack in rad at mo k seal solve it but Want it sorted that all can I put separate rad and cooler in
Cool seem a massive unit tho with fans and stuff buy quessibg part of the air con etc
