Catch can help!
andya3turbo
Skelmersdale
Just renewd my block breather pipe with a silicone reducer and while i was there i did a few tests with the engine running, i put my finger over the breather pipe and the idle seemed to smooth out abit and pick up then took my finger off an it went bit unsteady not huge just chasnge in tone,
I currently have a catch can setup and it comes out the rocker cover to the T piece then one pipe go's the catch can and the other go's to the block breather then one gos from the catch can to the inlet pipe or TIP, question is can i remove the tip and blank it off and use a breather filter on the can?
Yes you can mate but it may start to smell a bit at lights etc.. so you may want to do what I do and run a pipe from the can down under the car so the fumes exit away from the bay. Keep it clear of the tyres obviously thow :)
Keiran
