ESP Warning light on.
DaztheGuv
Member
Stoke on Trent
Hi hope someone can help me, my esp warning lamp came on in my car a few weeks ago, so did a VCDS scan on it, and a couple of defects cam01-Engine -- Status: OK 000003-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0050
Revision: 5BH16--- Serial number: AUX7Z0G3FNO0AW
Coding: 01030003180F0160
Shop #: WSC 06314 000 00000
VCID: 3778B7A94656A5B
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0021128
VCID: 72EE46BD6DB4003
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AD HW: 8P0 820 043 AD
Component: KlimavollautomatH19 0360
Revision: 077479 Serial number: 8P0820043AD
Shop #: WSC 00000 000 00000
VCID: 6ED652CD798C243
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000007049621
Coding: 158E4F07A014100000000000000000000008EE175A0500
Shop #: WSC 06435 000 08192
VCID: 408ADC751398E23
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06435
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H13 4220
Revision: 91H13422 Serial number: 0037W0G1HT6P
Coding: 0071612
VCID: 4798C76936B6D5B
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 418CD9711892EBB
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 J HW: 8P0 920 981 J
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2243G004000719
Coding: 0005418
Shop #: WSC 00726 210 83187
VCID: 3F88DF896E669DB
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 330010741810E9
Coding: FD0F03C807000101
VCID: 2F688FC9BE066DB
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 3666BAAD415C5C3
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC
Its shows fault code on ABS and code on AWD.
Can anybody advise me on problem, and cost to get it sorted please?
Many thanks,
A very nervous Daz.
oh no. g201 sensor!!
do you have facility with your vagcom to view the actual values of the brake fluid pressure sensor (the g201)?
is it stuck on like 215bar without you even pressing the pedal?
if the abs pump/unit is the type where the sensor's an integral part of the pump then its £££.
get it down to the dealer and throw a temper tantrum till they do it for free.
this is a very very very common fault.
if your out of warrenty, it used to be, 500-900 depending on how much contribution from audi.
but nower days theyve realised the fault and you can now purchace just one side of the abs pump relativly cheaply. and no need to code it in.
this is the bit.....
eBay - The UK's Online Marketplace
could you check that actual value to confirm? then you can go into the dealer and know all the facts.
for some history on the known fault, just google "golf touran g201" throws up all the relavent threads on all sorts of forums.
yeap, oh dear.
Seems me and Daz are living a near parallel experience.
Almost geared up to have my A3 in for a fix up. ABS repair Kit fitting for Brake Pressure Sensor G201. Just thought I'd see if I could get any further advice, especially from you Nige (great advice given before).
Did you get sorted Daz?
My scan code below.......................................................
Wednesday,18,April,2012,13:30:49:12592
VCDS Version: Release 11.11.3
Data version: 20120401
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Control Module Part Number: 1K0 907 379 AC HW: 1K0 907 379 AC
Component and/or Version: ESP FRONT MK60 0101
Software Coding: 0023170
Work Shop Code: WSC 06314 000 00000
VCID: 73EE662412AE091
1 Fault Found:
719 unit
282. repair kit
Address 03: DTCs cleared
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 77
VIN: WAUZZZ8P67A195638 Mileage: 84100km/52257miles
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 021 LG HW: 03G 906 021 AN
Component: R4 2,0L EDC 000SG 9558
Revision: --H06--- Serial number: AUX7Z0G2FNR061
Coding: 0000072
VCID: 6FE66A547E862D1
Readiness: 0 0 0 0 0
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
1 Fault Found:
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Revision: 118478 Serial number: 8P0820043AC
VCID: 6DDA705C748ADF1
Revision: 00H43000 Serial number: 00000006854299
Coding: 01884F01B014100000160000160000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 4084F9E81398E29
Coding: 00062736
Shop #: WSC 06314
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H13 4260
Revision: 91H13426 Serial number: 003620G4EHBU
Coding: 0071612
VCID: 4280F3E01D94F09
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AH HW: 1K0 953 549 AH
Component: J0527 036 0070
Coding: 0000012
VCID: 78F451080BC86A9
Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
Revision: D0H20004 Serial number: 2242G004014910
Coding: 0004418
Shop #: WSC 00409 210 91017
VCID: 3B7E8E047A7E811
Revision: H12 Serial number: 33001073200357
Coding: 3D3F03C207002103
VCID: 2F66AA54BE066D1
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0G2FNR061
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000688
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 356A983C5C5A571
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H08 0070
Coding: 9980202002186D098505489FC637
VCID: 3F86FA146E669D1
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674702724079
VCID: F1E2EC2CE8B2BB1
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000688
VCID: 4182FCEC1892EB1
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 G HW: 8P0 035 186 G
Component: R Concert2+ H16 0221
Revision: 00H16000 Serial number: AUZ1Z3G9099071
Coding: 0410311
VCID: 36689F30415C5C9
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000144
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000144
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005110785
Coding: 0000122
End ---------------------------------------------------------------------
If you've tried doing any basic settings, removed battery power for 5 minutes, cleared the fault & its come back, then its the dreaded I'd say, as nothing else is faulting on that log.
