only diff is mine has drl not auto lights
Hayley's off with the car, I'll get it when I get it back later, or 2moro when I'm working on it all day. Cheers Wez.
Not had chance yet, will try sort it later brother.
from the OP i can see that the pic you have shows you still have the manual range control adjuster instead of the DRL roller which means you still have halogen headlights and not the bi-xenon with DRLs
the part number for that switch (with manual range control roller wheel) is 8J2 941 531 L
that shows up on ETKA for cars that have front and rear fogs, auto lights, coming home button and manual range control roller. it also has a code to show its the aluminium switch. price is roughly £65 from Audi but ask Stoke Audi here on the forum as i got the above switch from them at £63.
This is the chrome version headlight for cars that have Auto lights, bi-xenon headlamps with the drl lights.
part number: 8J2 941 531 E
Its actually from a TT not an A3 but fits and works perfectly.
Any chAnce of that part number N8?
Forgot all about it, working on the car tomorrow in fact, so will tell you what mine is, incase it differs from Ads.Ash I've been keeping an eye on this thread. I retrofitted the the Bi-xenons+leds in my 2009 a3 and I want the CH/LH function but I don't have auto wiper light sensor installed. I have been told to get CH/LH function I need to install this headlight switch that you have pictured. Do you know if this is true or can I just do the recoding and the ground wire trick?
Il check that headlight switch for you, but I don't think that will work on pre facelift cars. I have seen facelift headlight switchs to not work and leave the headlights on all the time regardless of headlight position
Wez, I put the part no up for you 2 weeks ago![]()
You need a prefacelift tt one. Do u have auto lights?
Can you not just get any old facelift light switch, then swap over the big dial?
