17704/P1296/004758 - Error in Mapped Cooling System
Possible Symptoms
Cold start issues
Possible Causes
Coolant Temperature Sensor (G62) faulty
Coolant Thermostat faulty
Possible Solutions
Check Coolant Temperature Sensor (G62)
Check Coolant Thermostat
Special Notes
Check the stored Freeze Frame data with this fault code. Freeze Frame information will be found in the fault code description (if the module supports it) or in Generic OBD-II if the vehicle complies with those regulations.
Freeze Frame data stored at -40*C is generally an indication of a faulty ECT or wiring.
Freeze Frame data stored at +140*C is generally an indication of a faulty ECT or wiring.
Freeze Frame data stored with in the 68*C ~ 80*C range is an indication that the vehicle was close to, but not within, the cooling systems normal operation range. The Thermostat itself or Cooling system components may be at fault.
