After establishing that the only dock extension cable that seems to work with the ipod AMI cable was the cablejive dockxtender.
I finally plucked up the courage to remove the glove box this morning!
After removing the glove box, I carefully extended the hole at the top of the glove box (trying not to cut the airbag on/off switch wires) to route the dockxtender cable out.
As I purchased both the 2ft & 6ft cables, Iâve connected them together and have managed to the get the cable up and through into the arm rest (eventually - by removing the rear air vents and some luck)
So the cable now exits the where the âaux inâ is on non-AMI cars.
Which is where i wanted the cable as i keep my phone in the slot next to the cup holders.
Iâm really pleased with the results, just need to find a square grommet to cut and go around the cable - any suggestions??
Keef
Keef
